We have been having issues with our oscillating knife on our Multicam CNC flat bed router. We are are cutting into 12mm PET panel using a standard round point blade with Enroute 5.1 being the software we use to nest and set up our files.
What we are noticing that the finished panel comes out slightly different in size to what we are wanting. For example, if we have a 100mm x 100mm panel to be cut it cuts out at 101mm x 101mm. If we change the toolpath direction we get 99mm x 99mm. We cannot work out why the knife is not cutting centrally to the line rather than on either side of the line.
Suspecting it is a setting in Enroute rather than having to do with the machine itself. I could be wrong though.
The knife is setup as an 'endmill' and we define this toolpath using the 'engraving.'
Any help is much appreciated.
