HEIDENHAIN at SPS IPC Drives 2014
Hall 7, Booth 190
New encoders for highly precise and safe determination of the position and orientation
Wherever and whenever rotary encoders, angle encoders, or linear encoders are needed for exact, reliable, and safe determination of the position and orientation, HEIDENHAIN is the first choice. Numerous new encoders for use in electronic automation technology confirm this at the SPS IPC Drives trade show in Nuremberg.
Here are some examples of what HEIDENHAIN will show visitors at Booth 190 in Hall 7:
+ New solutions for rotary encoders and angle encoders with functional safety and additional mechanical fault exclusion for safety-related applications.
+ Compact rotary encoders of the ECI/EQI 1100 series with a housing diameter of only 36.5 mm for electrical drives, also for use in applications with functional safety up to SIL 3. + The mounting strategy for simple installation of the LIC 2100 linear encoders with amazingly large mounting tolerances at a measuring accuracy of ±15 µm for automation technology.
+ Especially large angle encoders of the ECA 4000 series with drum inside diameters of up to 512 mm for determining the position and orientation of exact rotary axes.
The HEIDENHAIN encoders presented at SPS IPC Drives cover not just solutions for nearly all levels of accuracy requirements and mounting situations, but also numerous company-specific serial interfaces. This means that the accuracy and quality you are accustomed to from HEIDENHAIN is available for nearly every possible application.
