HEIDENHAIN at the Control 2017: Product Innovations with Added Value for Your Production
At the Control 2017 in Stuttgart, we will show you new product developments that will ensure higher accuracy and greater efficiency in your production. Visit us from May 9 to 12 at Booth 4307 in Hall 4 and inform yourself on topics including:
- The new HEIDENHAIN-SPECTO ST 3087 RC length gauge. It is suitable for applications in harsh environmental conditions and enables time-and cost-saving in-process measurements, for example in machining production areas. .
- The new LIP 6000 exposed linear encoder with interferential scanning. It offers a very small interpolation error of only ±3 nm, a low noise level of only 1 nm RMS and a base deviation of less than ±0.175 μm in a 5 mm interval. This makes it particularly suitable for applications that require constant speed control or very high position stability at standstill.
- The new motorized angle encoder modules for high-precision rotary axes in metrology. They enable you to significantly reduce mounting and adjustments costs in your production, because we provide you with a highly integrated assembly with tested properties and the specified accuracy in the application. We have already completed the necessary assembly and adjustments of all individual components.
