588,484 active members*
4,923 visitors online*
Login Register
HEXAGON - Banner
HEXAGON Forum
Design. Make. Inspect.
Okuma > please, help me with general pinch turning questions
Results 1 to 8 of 8
    Jun 2015
    4171
    hello
    let's suppose that 2 tools begin an od pinch turning at same x and :
    ... same z, thus the cutting edges are mirrored:
    ...... after final z is reached, should there be enough to dwell the spindle for half a revolution in order to achieve a clean face ?
    ...... did each tool removed the same quantity of chips ?
    ... different z, thus both cut the same diameter, but one is a bit behind on z; what is the maximum z difference allowed, after which pinch turning no longer occurs ( only leading tool will cut, while the following will cut air ) ? is it g95 feed / 2 ?
    what is the best approach for difference in relative position between each other tool, like one should be higher on x, and in front on z ? is there a recomandation to have the upper turret tool on higher x, or the lower turret tool on higher x, or it doesn't matter ? should the tools differ on both x&z, or only x, only z, or no difference ( like a mirror cut ) ?
    if a difference in x is used, then should it be like each tool to cut the same doc ? or is there a recomandation for 40-60% for some reason ?
    if a difference in z is used, then what should it be, and why ? is it true that, if a z difference exists, then the end face won't look smooth, because each tool finished at different z values ? or, even if a z difference exists between tools, is possible to reach same z end for both tools ? or generic z difference is small, making the aspect of the end face to be accepted ?
    please, are there some general guidelines ? like practical approaches, ideas based on which the code approach is built ( beside the need for syncronized labels between turrets ) / kindly
    Mar 2009
    1982
    Re: please, help me with general pinch turning questions
    so many academic questions.
    Upper turret should take most of the job, because the chips and heat are removed more efficient, than on the lower turret. I think, it is mentioned in the manual.
    "half a revolution" doesn't make sense, unless the tools are active. Theoretically, yes - should be enough.
    Jun 2015
    4171
    hy mr bunny i had some doubts, but after seing a few youtube videos, i got it fixed
    if both turrets are identical, is that because is considered that the upper tool has the insert face towards y-, or is there also something else to consider ?
    i heared that on a multus with lower turret, one should definetly go harder with the turret, since the upper pivot turret is a bit fragile, or at least not as rigid as the lower turret when it comes to roughing / kindly
    Mar 2009
    1982
    if both turrets identical, then yes - only heat removal is important. They never are identical. The upper is more rigid - traditionally, if no balance unit, the weight of the upper turret does the work also. The design of the lathe, turret arrangement allows the upper turret to be just bigger. Speaking about Multus and MacTurn - yes. The lower turret is the real turret. The upper is universal multi function "all-in-one" - means less rigid.
    Apr 2009
    1262
    When synchronized the turrets will feed at EXACTLY the same Z position if started at the same Z so they are at a 1/2 rev difference when encountering a shoulder. That is what makes the balanced load possible. They can be used however you like. Balanced, different Z chasing , different X chasing - your choice - all is possible.
    This is also why during a LAP cycle each block should have a P code in order to keep them in sync when pinch turning.
    Heavy interrupted turning is generally avoided on the upper Multus multifunction turret since realignment if crashed is time consuming and the turret is more fragile like algirdas says.
    Experience is what you get just after you needed it.
    Jun 2015
    4171
    the upper is more rigid - traditionally, if no balance unit, the weight of the upper turret does the work also
    hy mr bunny yup, good point; it means that there is more turning capability for the upper turret, while the lower one will have to always compensate it's mass
    please, what is a balance unit ? are there such okuma machines ? i guess that it's used for heavier turrets, etc, like an ascensor counterweight
    lt twin star lathes have identical turrets
    hy mr wizard i recently saw a few examples of simultaneous machining, covering not only simetrical turning, but also milling and asimetrical toolpaths
    i guess that balanced turning is best for machining without a tailstock, or at least alows machining a part with bigger L/D, that would be impossible to handle with a single turret
    yes, such syncronizing is needed, and especially the 1st pair is critical
    considering that rapids are identical, i wonder if it would be possible to pinch turn only with a single pair of P codes ? considering the rigidity of the machine, i don't think that it will have such a big error at the end, in order to justify P codes for each block / kindly
    Mar 2009
    1982
    like an ascenstor counterweight
    exactly: there was just a weight balance installed on older lathes. Pneumatic compensation is a modern solution. It's for heavy upper turrets - big machines only.
    Sure, Okuma is using that.
    Aug 2010
    190
    Quote Originally Posted by OkumaWiz View Post
    i sincerely apologize for bringging this thread back to life, but i suppose it proves i used the search function lol! Wiz, would it be possible for you to send me a program example of what you are talking about here? i would like to get into some pinch turning and it sounds like this method may help a lot to sort out some timing issues i am having. thanks!
  1. Pinch (Balance) Turning?
    By sidswiss in forum CNC Swiss Screw Machines
    Last Post: 10-18-2021, 12:29 AM
  2. Pinch turning or Balanced turning
    By pradeep in forum Mori Seiki lathes
    Last Post: 09-07-2010, 07:55 PM
  3. Pinch Turning in PartMarker
    By PACMan1779 in forum Uncategorised CAM Discussion
    Last Post: 01-06-2010, 06:36 PM
  4. Please enlighten me on pinch turning...
    By Letter Buck in forum G-Code Programing
    Last Post: 05-16-2008, 07:43 PM
