Hi !
Noticed problem as can be seen , puzzles us right now.....
https://www.youtube.com/watch?v=OJ7uYXR0xwM
Hi !
FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , VH-65 (A-axis) ,3ph 400V , metric, NO conveyor, No palette. (+alternative DC AMP)
You sure the tool can go in 180 deg off without hitting the drive dogs.
Hi.
Put the clock against the spindle bore and see if it's correct, if so the problem is in the holder-Haimer
If you rotate the Haimer probe in the tool holder 180 deg and it behaves exactly the same then the Haimer is correct and the holder isn't.
If the problem is in the holder then you have corected this when you zero adjust the Haimer, and the correction you did will if the holder is rotated 180 deg be an error twice as large as the error you corrected in the first place.
Hope this helps.
Fredrik
