Nine9
18
Nine9
18
NC Spot Dril - the first innovator since 2001
nine9-jic-tools news Image
In 2001, Nine9 lanuched NC Spot Drill , it was the classical and iconic product in Nine9 product history.
Nine9 Spot Drill is more than just a spotting drill, but a multiple functional tool. Inserts of NC Spot Drill are interchangeable and covers various angles from 60° to 145° for different purpose applications, such as spotting, chamfering, grooving, engraving, and corner rounding, etc. Various insert grading on the same holder can machine any materials. It is economical and save your tooling cost.
Why spotting? Spotting produces a shallow hole to get better hole position enabling to produce more accurate final product. Ideally, the proper spotting angle should have larger point angle than that of your drill, so the center of a drill shall be the first point to contact workpiece to avoid the drill walked or moved in starting drilling.
Nine9 spotting tool is not only produce better hole position allowing the drill to machine in higher feed rate, extend tool life of drill and improve production efficiency, it also ensure geometrically uniform holes to stabilize products quality.
? Stop by Booth A13, Hall 005 and let’s talk about the future of machining!
Join us for an unforgettable start to EMO 2025!?
Responsible for the content of this press release: Jimmore International Corp. NINE-9
