Nine9
18
Nine9
18
Nine9 Ergo Power Mill
Have you calculated how much time you spend to clean and check ER spring collet every time before and after using? And feel sorry that the maximum clamping range is only 10mm for ER16 spring collet?
ERgo Power mill, the latest development from Nine9, is monoblock design. It has minimal assemble parts, including ER taper cutter, Nine9 ER nut, and pin. It eliminates accumulation of dirt and dust which is easier to clean and save plenty of maintenance time.
ERgo Power Mill is integrated ER taper-shank indexable milling cutter. The ERgo taper is clamped and directly contact with spindle, which has better rigidity, and run-out accuracy. There is a testing on Swiss type STAR-20 machine, material is SCM440 / HRC33°, using ERgo ER16 Ø12mm cutter to do slotting job. DOC can achieve 4.5mm in one pass, it saves 50% of machining time compared to solid carbide end mill. More, the surface finish is excellent because of no chatting.
ERgo ER16 cutter offers a wide range diameter from Ø10mm to Ø32mm. No more sorry for the maximum clamping range. To complete this system for all users, ERgo ER11, ER20, ER25 are also available for your choices.
By using Ergo Power Mill, you can get:
  • Better rigidity for high performance cutting
  • Indexable insert type, saving set-up time
  • Better run-out accuracy
  • More efficiency and possibilities to machine bigger parts
Stop by Booth A13, Hall 005 and let’s talk about the future of machining!
Join us for an unforgettable start to EMO 2025!
Contact our team for more information. * [email protected]
or visit https://nine9.jic-tools.com.tw/ergo-dia-10mm-to-32mm-milling-cutter.html
? Watch video https://www.youtube.com/watch?v=szcSXmGKp84
Responsible for the content of this press release: Jimmore International Corp. NINE-9
