PEPPERL+FUCHS
91
PEPPERL+FUCHS
91
Exceptional Performance in PLC-Based Applications
pepperl-fuchs news Image
IO-Link masters enable efficient and reliable communication between management and sensor/actuator levels. They transmit sensor data to higher-level information systems and can also receive data from there.
The new ICE11 IO-Link master for PLC-based applications is multiprotocol-capable and now supports not only PROFINET, EtherNet/IP, and MODBUS TCP but also EtherCAT and CC-Link IE Field Basic. It can be used worldwide in various application areas such as robotics, intralogistics, and motion control applications.
The IO-Link masters are extremely powerful and can be used for real-time applications with cycle times down to the microsecond range, depending on the protocol used. For instance, the EtherCAT variant offers a ~250 µs cycle time. The devices also comply with the latest IO-Link standard V1.1.3, making them particularly sustainable.
Responsible for the content of this press release: Pepperl+Fuchs SE
Pepperl+Fuchs SE
