RÖHM
493
RÖHM
493
The compact and value-for-money Roehm all-round vice
roehm news Image
The compact and value-for-money Roehm all-round vice: with high-speed clamping-range adjustment and flexible range of application
Roehm clamping-technology experts show just how easy and fast you can respond to an extremely wide range of requirements from production with their MSR vice.
The MSR provides everything you need for flexible use: fast clamping-range adjustment using a pin system, ease of operation and compact design. But the clamping-technology specialists' solution is a perfect one not only if you need to adjust quickly to various chucking situations. The strengths of the mechanical vice come to the fore particularly if space is at a premium on milling machines and machining centres. The hardened body, its excellent value for money and the low-cost clamping jaws round off the overall package.
Stefan Balletshofer, the designer responsible for the vice, puts it in a nutshell when he says "for milling with pull-down spring return, the MSR is a low-cost alternative to more expensive vices." The MSR also features a low-wear, low-maintenance spindle which makes it a really strong workhorse for day-to-day use.
The scope of delivery includes everything you need to get you off to a good start quickly: pull-down jaws, chuck handle, workpiece stop and clamping claws.
Currently available at attractive conditions in our Steel Icons Promotionhttp://eshop.roehm.biz/roehm_de_en/online-shop/promotions/promotion-steel-icons-2017-1.html.
Find more information about the MSR Vice at: www.eshop.roehm.biz
Responsible for the content of this press release: RÖHM GmbH
RÖHM GmbH
