RÖHM
493
RÖHM
493
Workpieces perfectly palletised and time and money saved in the process
When being setup, machine tools are not used productively and don’t contribute to earnings. The clamping process of the workpiece is also a time-consuming and cost-intensive factor. That is why it is necessary to reduce the setup times to a minimum, especially in single part and small batch manufacturing. RÖHM, the clamping and gripping specialist, solves this challenge with its zero point clamping systems. Here, RÖHM offers two systems for different requirements. Both meet the requirements for the best-possible utilisation of the machine’s capacity by swapping pallets in and out in just seconds.
Due to the robust and rust-resistant construction, both systems are suitable and can be used throughout, starting with machining, continuing with eroding up to the measuring machines. The workpiece is setup outside the machine tool while the machine is running. Due to standardised interfaces, the pallet with a clamped-in workpiece can be used for all manufacturing processes without any zero point loss.
RÖHM puts high priority on offering the right system for any application. Hence, the Easylock zero point clamping system prevails in detail with a large scope of functions and an attractive price. Possible fields of application range from hydraulic or pneumatic actuation up to manual actuation. The Easylock Plus expansion is also equipped with system control with an integrated cleaning function. The Easylock is suitable for a large number of demands that are placed on palletising systems today. In the process, it achieves a change-over accuracy of 0.005 mm.
RÖHM has its Power Grip palletising system in its programme for high demands placed on precision. As an ultra-precision system, it allows change-over accuracies of 0.002 mm making it considerably more accurate than the Easylock. In addition, the clamping monitoring is directly integrated. In short, RÖHM meets the highest demands with the Power Grip.
As a system supplier, RÖHM offers palletising and clamping devices from a single source. The prefabricated pallets can be combined in a modular system with a multitude of RÖHM standard clamping devices. There is no need at all for costly and time-consuming adaptation of the clamping devices or pallets. In addition, RÖHM offers prefabricated pallets for vices and chucks as well as universal pallets.
Responsible for the content of this press release: RÖHM GmbH
RÖHM GmbH
