Sandvik Coromant UK
131
Sandvik Coromant UK
131
New advanced nozzle technology optimizes the use of coolant
Photo Caption: Sandvik Coromant introduces new advanced nozzle technology guaranteeing precise coolant jet flow
Accurate targeting of coolant during machining gives maximum effect in chip evacuation.  However precision and pressure are two equally important aspects of coolant. A high precision coolant requires lower pressure. The higher the pressure, the more demanding applications can be machined with excellent results.
Sandvik Coromant leads the way in cooling technology solutions through advanced nozzle technology and dedicated insert geometries for steel, stainless steel and HRSA material for all machining applications. And March 1st sees further additions to the growing range of options to apply coolant in the machining process.
The range of new insert geometries and customized tool holders, feature fixed nozzles that guarantee a precise coolant jet flow to get right to the centre of the cutting zone.
Advanced nozzle technology
The coolant flows from the pump to the tool through nozzles directed exactly at the cutting zone. This produces a wedge of coolant that efficiently removes the heat from the cutting zone and forms the chip. Improved chip control and longer tool life are just two of the benefits which contribute to secure and predictable machining, preventing unplanned machine stoppages.
Increased productivity can even be achieved in tricky applications and in materials which are difficult to machine, regardless of the pressure you use.
Low pressure 7–10 bar (100–150 psi)
When using low pressure the new Sandvik Coromant  CoroTurn HP holders, with high precision nozzles,  outperform regular tool holders which can have a tendency to flood coolant ,providing improved chip control and better process security in steel and other common materials. Substantially higher cutting data can be applied is another welcome effect.
70–80 bar (1000–1200 psi)
For demanding materials, such as duplex stainless steel and HRSA material, higher coolant pressure is needed. The unique CoroTurn HP nozzle technology in combination with the new -SMC, -MMC, - PMC insert geometries provide a productivity that will impress.
150–200 bar (2200–2900 psi)
Few machines provide solutions for these pressures, however Sandvik Coromant offers standard holders and inserts that allow for up to 275 bar (3900 psi) of coolant pressure. Coromant Capto clamping units for high pressure coolant with 200 bar (2900 psi) coolant pressure capability provide unrivalled performance ensuring that machine utilization is optimized through reduced set-up and production time.
Tool holders
The Sandvik Coromant advanced cooling technology has until now been a solution primarily for customers using quick change with Coromant Capto®, SL- and QS holding system. Now, the same premium technology can be applied with general shank tools, making it possible for everyone working with wet machining to utilize this highly productive coolant solution, even in small lathes.
For more information on the new range of options for machining with coolant visit www.sandvik.coromant.com/productnews
About Sandvik Coromant
Sandvik Coromant is a global leading supplier of cutting tools, tooling solutions and know-how to the metalworking industry. With extensive investments in research and development we create unique innovations and set new productivity standards together with our customers. These include the world's major automotive, aerospace and energy industries. Sandvik Coromant has 8000 employees and is represented in 130 countries. We are part of the business area Sandvik Machining Solutions within the global industrial group Sandvik.
For more information visit the website at www.sandvik.coromant.com.
– End –
Contact Details:
Nikki Stokes
Marketing Communications Specialist
Marketing & Sales Support
Tel: +44 (0) 121 504 5422
Email: [email protected]
Website: www.sandvik.coromant.com
Ref: SAN595A
Responsible for the content of this press release: Sandvik Coromant UK
Your message
