Productive alternative to groove milling
CoroBore® 825 SL face grooving heads deliver new levels of productivity
Photo Caption: Fig.1 - CoroBore 825 SL face grooving family with Coromant Capto
Fig.2 - CoroCut 1-2 - Corobore 825 SL face grooving family
Machine shops seeking competitive gain in face grooving applications should look no further than the new CoroBore® 825 SL face grooving heads from tooling specialist, Sandvik Coromant. This rotating axial face grooving tool offers a productive alternative to milling grooves for those operating in, or serving sectors such as pumps and valves, hydraulics and the pulp and paper industry.
The solution uses a standard SL32 blade and CoroCut 1-2 inserts, but features through-coolant capability for enhanced chip control. This, in combination with high levels of rigidity, allows increased cutting data.
Chip evacuation is a concern in any metalcutting operation but is critical when grooving because chips are more prone to being trapped inside a groove and being re-cut. As a result, through-tool coolant delivered right to the cutting edge can be enormously beneficial.
CoroBore® 825 SL face grooving heads offer radial fine adjustment for presetting purposes and are available for diameters from 47 to 1275 mm. For smaller diameters (47-150 mm) C6 and C8 adaptors are available, while for larger diameters (>150 mm) a dedicated face grooving head with CoroBore XL can be deployed.
The first choice insert geometries are -CM for small nose radii (0.2 mm) – the recommended starting value for feed rate is 0.15 mm/rev. However, if grooves with smaller width tolerances are required -GF geometry is the preferred choice. Here, a feed rate of around 0.10 mm/rev is the recommended starting value.
At last there is a high-productivity alternative to milling grooves – axial face groove machining for applications such as producing O-ring grooves has never been easier using CoroBore® 825 SL face grooving technology.
For applications involving other shapes, such as V-grooves for example, Tailor Made insert solutions are available.
About Sandvik Coromant
Sandvik Coromant is a global leading supplier of cutting tools, tooling solutions and know-how to the metalworking industry. With extensive investments in research and development we create unique innovations and set new productivity standards together with our customers. These include the world's major automotive, aerospace and energy industries. Sandvik Coromant has 8000 employees and is represented in 130 countries. We are part of the business area Sandvik Machining Solutions within the global industrial group Sandvik.
For more information visit the website at www.sandvik.coromant.com.
– End –
Contact Details:
Nikki Stokes Marketing Communications Specialist Marketing & Sales Support Tel: +44 (0) 121 504 5422 Email: [email protected] Website: www.sandvik.coromant.com |
Ref: SAN623A
