Sandvik Coromant introduces a new multi-edge rough face milling cutter
Photo Caption: CoroMill 357, the new tough multi-edge face milling cutter from Sandvik Coromant, achieves a high metal removal rate and superior productivity
Sandvik Coromant introduces CoroMill 357, a new tough multi-edge face milling cutter for roughing and cubing in steel and cast iron with high insert security.
In typical applications such as rough face milling, cubing, in intermittent component figurations, components with uneven stock or forgings, welding and castings, applying CoroMill 357 achieves a high metal removal rate and superior productivity.
The CoroMill 357 multi- edge design provides a cost efficient solution. Good production economy and reliable performance comes from the double sided thick pentagonal inserts housed in shim-protected tip seats.
Its secure and strong cutter body features an innovative insert clamping system that offers quick and easy insert indexing to save you time. Large support- faces radially, axially and on the base prevent deformation, ensuring a consistent performance.
Suitable for ISO 50 and larger machines CoroMill 357 takes a depth of cut up to 10 mm (0.394 inch) with a feed per tooth up to 0.7 mm/z (0.0276 in/z)
CoroMill 357 is available from March 1st 2013 in diameter sizes 100-315 mm (4-10 inch)
For more information on the new CoroMill 357 visit www.sandvik.coromant.com/productnews
About Sandvik Coromant
Sandvik Coromant is a global leading supplier of cutting tools, tooling solutions and know-how to the metalworking industry. With extensive investments in research and development we create unique innovations and set new productivity standards together with our customers. These include the world's major automotive, aerospace and energy industries. Sandvik Coromant has 8000 employees and is represented in 130 countries. We are part of the business area Sandvik Machining Solutions within the global industrial group Sandvik.
For more information visit the website at www.sandvik.coromant.com.
– End –
Nikki Stokes Marketing Communications Specialist Marketing & Sales Support Tel: +44 (0) 121 504 5422 Email: [email protected] Website: www.sandvik.coromant.com |
Ref: SAN594A
