Sandvik Coromant introduces the high precision hydraulic chuck, CoroChuckTM 930
Photo Caption: CoroChuck 930, the high precision hydraulic chuck from Sandvik Coromant, for secure tooling performance in milling and drilling operations
March 1st sees the launch of CoroChuck 930. This high precision hydraulic chuck from Sandvik Coromant brings a secure tooling performance to milling and drilling operations. Perfect for meeting the demands for high run out precision, extensive tests have shown this new hydraulic chuck provides the best pull-out security available.
Fulcrum technology
The secret behind the high precision and pull-out security is in the optimized design of the brazed membrane which allows for maximum secure clamping with two supports on each side (fulcrums).
This design ensures excellent torque transmission to improve the performance of solid carbide end mills, drills and reaming tools. This performance is repeated over multiple clamping cycles to retain high quality component surfaces and extend tool life. Additionally, the CoroChuck 930 is designed with dampening features that minimize vibrations during the machining process.
Based on a hydraulic tool clamping system, the CoroChuck 930 can be quickly tightened or released with a dedicated torque wrench, improving efficiency through quick and easy set-ups and changes. No external equipment is required to clamp or unclamp the system.
The chuck holds tolerances within microns to improve tool precision, surface finish and productivity.The precision run-out can be measured at <4 μm (157 μinch) at 2.5 × DC.
CoroChuck 930 is suitable for all types of machine tools that either have a rotating spindle or workpiece; Lathes, Multi-Task machines, Machining Centres and driven tools in Turning Centres, and Vertical Turning Lathes.
Available in pencil, slender and heavy duty design, CoroChuck 930 is balanced according to DIN 69888.
For a more information and a closer look at the new CoroChuck 930 visit www.sandvik.coromant.com/productnews
About Sandvik Coromant
Sandvik Coromant is a global leading supplier of cutting tools, tooling solutions and know-how to the metalworking industry. With extensive investments in research and development we create unique innovations and set new productivity standards together with our customers. These include the world's major automotive, aerospace and energy industries. Sandvik Coromant has 8000 employees and is represented in 130 countries. We are part of the business area Sandvik Machining Solutions within the global industrial group Sandvik.
For more information visit the website at www.sandvik.coromant.com.
– End –
Contact Details:
Nikki Stokes Marketing Communications Specialist Marketing & Sales Support Tel: +44 (0) 121 504 5422 Email: [email protected] Website: www.sandvik.coromant.com |
Ref: SAN593A
