Guangzhou Sino Dro Co., Ltd
SINO Absolute Linear Encoder Hardcore Testing
sino-ld news Image
SINO absolute Linear Encoder
Absolute measurement: Accurate upon startup, no need for "zeroing": The SINO absolute linear encoder adopts absolute encoding technology, and there is no need to perform "zeroing" operation after the machine is turned on. The current position can be directly read, greatly reducing the equipment startup time.
Strong anti-interference ability: adopting a closed structure, the aluminum shell protects the grating, reading head and guide rail, avoiding the entry of dust, debris and cutting fluid, and the sealing strip keeps the shell sealed.
Wide adaptability: easily compatible with mainstream systems: The SINO absolute linear encoder can perfectly adapt to mainstream CNC systems such as BISS-C, SSI, Yaskawa, Fanuc alpha i (Fanuc05) protocol, Mitsubishi, etc., and can be quickly installed without complex debugging.
Yangsen Machine Tool Fanuc System Testing
Recently, Yangsen Machine Tool Factory conducted extreme testing on the main models equipped with Fanuc system - allowing the equipment to run continuously at full load for 24 hours, and then rigorously testing the Z-axis repeat positioning accuracy.
The SINO absolute linear encoder demonstrated amazing performance in this test. As the "eye" of machine tool accuracy feedback, its data stability directly affects positioning accuracy.
Responsible for the content of this press release: Guangzhou Sino Dro Co., Ltd
