Sloky
7
Sloky
7
Eliminating Screw Head Damage with SLOKY Torque Screwdriver
sloky-jic-tools news Image
? CASE STUDY
In the die & mold industry, screw head damage can lead to costly cutter body replacements and even broken inserts. One manufacturer struggled with recurring screw damage, driving up operational costs and causing production delays.
The Challenge: Before Using SLOKY
❌ At least 4 cutters damaged in a month, due to overtightened or damaged screws
❌ Broken inserts, leading to additional replacements
❌ Increased repair and maintenance costs
❌ Production inefficiencies caused by unexpected tool failures
The Solution: SLOKY Torque Screwdriver
Zero cutter body damage – precise torque control eliminates overtightening
No more broken inserts – improved screw integrity extends tool life
Cost savings – fewer tool replacements and lower maintenance costs
Higher efficiency – streamlined operations with consistent, reliable screw tightening
This was the company’s first experience with a torque-controlled screwdriver, and the results exceeded expectations. After seeing the benefits firsthand, they implemented SLOKY across all their tightening processes—achieving greater reliability, lower costs, and enhanced productivity.
Facing similar challenges? It’s time to rethink how you tighten your screws!
Come to visit us at EMO2025- Hall 005, A15 to explore more!
Responsible for the content of this press release: Jimmore International Corp.
