Smart Torque Everywhere Possible
SLOKY torque tool is the solution to supply precise insert screw tightening
As a tool maker, you might meet the situation since customers may not aware the importance of #torque_control for clamping insert screw. Often we found the insert is not locked correctly result in the insert cannot sit in the pocket completely. Once the insert does not fit into correct position, it gets vibrated during machining process and damaged easily. This problem is solved after we suggest customer lock the screw by using adequate #torque_driver.
It proves torque control can avoid damage of screw, increase the life of screw and insert. Moreover, it can optimize the milling performance when machining with multi-teeth.
“ SLOKY torque tool ” is the solution to supply precise insert screw tightening. With the #“click”_sound, user can easily notice when the demand torque is reached and the torque value remains still. #No_over_tighten_or_under_tighten.
Sloky has #reversible character make user use the same torque tool to loosen the screw. Each patented Sloky adapter had been tested by precise equipment before shipping to make sure its quality and life time can reach DIN EN ISO 6789 specification standard.
“Adapter” delivers torque control itself, its value also can be customized from #0.1_to _18Nm to meet different demands. The special #color_identification makes user recognize adapter and its corresponding bits quickly and correctly.
No matter shape, or to fit different bits, torque value, and specific color ring, all can be customized!
If you are interested in using Sloky torque tool to optimize the machining performance, just contact us for a try! [email protected]
