SMS group
32
SMS group
32
Clutch-type screw presses produce components for turbine applications
sms-group news Image
The aviation industry constantly strives for greater energy efficiency and performance, particularly in aircraft engines. These advancements influence operational costs and environmental sustainability. To meet these demands, turbine components require sophisticated alloys and complex geometries. SMS group has positioned itself as a global leader in forging technology, offering advanced clutch-operated screw presses for closed-die forging. These presses empower manufacturers to produce high-quality components with precision, reliability, and cost-effectiveness.
The precision of the SPKA slutch-operated screw press
Clutch-operated screw presses represent a significant step forward in forging technology. Weighing up to 2,900 tons, these machines deliver high forming energies and precise process control, with a blow force of up to 365 MN. This capability allows forging of challenging materials while preventing overheating and undesirable microstructures. These presses are essential for manufacturing structural parts, landing gear components, turbine blades, rings, and disks for aviation and energy sectors.
Applications of closed-die forged parts in aviation:
  • Closed-die forging presses play a central role in the manufacturing of components for the aerospace industry, particularly in the production of high-precision, durable, and complex-shaped parts. Under high pressure, metals are placed into a predefined mold (the die) and compressed. Examples are:
  • Turbine blades
  • Engine shafts
  • Highly stressed structural components
Unique operating principle
The SPKA clutch-operated screw press features a continuously rotating flywheel that stores forging energy as kinetic energy. A hydraulic clutch connects the flywheel to the spindle, accelerating the ram toward the workpiece. This design separates forming energy and force, allowing independent control. Optimized flywheel size and energy supply ensure cost-effective production with high forming energies.
During operation, the flywheel rotates with the clutch open, driven by a frequency-controlled asynchronous motor. When a stroke is initiated, the spindle synchronizes with the flywheel speed via the hydraulic clutch, accelerating the ram efficiently and precisely.
Precise control with the SPKA clutch-operated screw press
High-strength, heat-resistant materials like titanium alloys, nickel-based alloys, and high-alloy steels demand controlled deformation energy and flow during forging. Precise control avoids defects such as cracks or inhomogeneous microstructures. The SPKA clutch-operated screw press is highly effective in forging turbine blades, disks and rings for aviation and power generation. Their resistance to tilting under off-center loads and large surface area under the spindle makes them ideal for structural components and landing gear parts. Their rigidity and accuracy ensure precision forging, meeting aviation's stringent demands.
Precision force control for optimized efficiency
The SPKA press offers precise control of forming force and low accelerated masses. Hydraulic pressure in the clutch allows accurate force setting and consistent maintenance throughout the process. This enables forging at maximum force regardless of forming speed, ideal for fast-cooling materials and complex geometries. The design minimizes synchronization time, ensuring maximum forming speed and force early in the stroke. This results in short stroke times and fast sequences.
Comprehensive technical service for enhanced forging press reliability
To maximize the reliability and efficiency of forging presses, SMS offers a wide technical service package that goes beyond standard maintenance. With extensive experience in screw press technology, including the SPKA model, SMS provides predictive maintenance solutions and utilizes advanced methodologies such as failure mode and effects analysis (FMEA). These proactive measures not only minimize unplanned downtime but also optimize production processes, ensuring consistent output quality.
Responsible for the content of this press release: SMS group GmbH
SMS group GmbH
