586,100 active members*
2,592 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
ViaCad / Shark > Defeaturing Tip with ViaCAD 2D3D 9
    Oct 2007
    9
    Hi All
    I made a video showing how you can defeature a part with ViaCAD 2D3D 9. The key tool is the Remove Face command which can be used on collections of faces such as blend, chamfers, holes and cutouts. The "tip" in this video shows a recent code change that combines the Deep Select tool with the Delete key to provide a quick method to remove faces.
    http://www.csi-concepts.com/Demo/vid...ureExample.mp4
    Normally defeaturing is associated with removing extra detail for CAE prior to meshing. But I find this tool also good for completely removing a feature and replacing with a new or modified feature. Some examples include removing a radial blend and replacing with a chamfer or replacing a countersunk with a counterbore.
    Tim
    Jun 2013
    443
    Re: Defeaturing Tip with ViaCAD 2D3D 9
    Tim. Thats awesome. Thanks for posting that tip I just used it and have often wondered if there was an easier way.
  1. 2D to 3D in ViaCad
    By Levictus in forum ViaCad / Shark
    Last Post: 02-13-2014, 02:14 PM
  2. ViaCAD 2D/3D vs ViaCAD pro
    By sortafast in forum Uncategorised CAD Discussion
    Last Post: 07-15-2013, 05:40 PM
  3. Anyone Here Using ViaCAD?
    By SCzEngrgGroup in forum Uncategorised CAD Discussion
    Last Post: 11-12-2012, 03:36 PM
  4. ViaCad 2D/3D
    By geoff3881 in forum Uncategorised CAD Discussion
    Last Post: 04-29-2012, 06:10 PM
  5. ViaCad 2D/3D v8 for Mac
    By JReed3 in forum Uncategorised CAD Discussion
    Last Post: 01-04-2012, 05:30 AM
