TMT
7
TMT
7
TMT TLV-850II Vertical Machining Center – Your Best Choice for High-Efficiency Machining!
tmt-tsunglin-machinery-technical news Image
TMT TLV Series vertical machining centers, engineered to meet the demanding needs of modern manufacturing for high precision, efficiency, and durability. The TLV series features C3-grade ball screws on all three axes, pre-tensioned and laser-processed to effectively reduce thermal deformation, ensuring exceptional stability and positioning accuracy even during prolonged operation.
The worktable is equipped with an automatic forced lubrication system, significantly enhancing machine lifespan and stability. An optional rotary table is available to reduce process steps and minimize downtime caused by loading and unloading, dramatically improving production efficiency. The machine base is widened and reinforced with a triangular support structure to provide superior stability and durability. The high-performance linear guideway system delivers high precision, fast travel speeds, and low wear, further boosting machining efficiency.
Moreover, the Z-axis column utilizes a highly rigid rib-reinforced structure to prevent twisting deformation, while the widened and extended saddle structure increases the travel distance of the guideways. Combined with the Y-axis large-span four-rail design and the X-axis dual-rail six-slide worktable, the TLV series significantly enhances load capacity and rigidity, especially in the TLV-1275, 1475, and 1675 models.
The TMT TLV Series vertical machining centers are the ideal choice for precision manufacturers pursuing ultimate efficiency and accuracy. We warmly invite industry professionals to seize this opportunity and experience the exceptional productivity and quality the TLV series brings.
For more information, please contact our sales team anytime!
Responsible for the content of this press release: Taiwan Machine Tool Co. Ltd.
