588,492 active members*
4,192 visitors online*
Login Register
EROWA - Banner
EROWA Forum
MetalWork Discussion > Punch iron angle bar hole and countersink in one swoop
Results 1 to 3 of 3
    Apr 2024
    I currently drill and then use countersink bit to make holes for standard no6 or no 8 screws. I would like to buy one of those electric hydraulic punching machines and use a punch and die of 4.2 mm to make a hole and the countersink. There are some companies that will create a custom die punch, but I think I found one that looks exactly like what they suggest. The story is in the pictures.
    Pic 1. my existing drill press drilled bard
    Pic 2. punching machine
    Pic 3. suggested punch / die
    Pic 4. suggested punch / die
    Pic 5. the punch die I want to buy (less expensive)
    My question is - will it work?
    I you can share how standard 90 brackets with countersink are made, why there isn't a common solution for this.
    Best, Ariel
    Attached Thumbnails Attached Thumbnails Anglebar sample.jpg   ElectricPunch.jpg   cleaveland.jpg   countersink punch 2.jpg
    Apr 2021
    39
    Re: Punch iron angle bar hole and countersink in one swoop
    I do not see any pictures
    Apr 2024
    It is possible that my account which is new, was not verified. Now it is, please let me know if the pictures are visible. I'm able to see the images - here's a direct ink to the post - https://en.industryarena.com/forum/p...p--468859.html
EROWA - Skyscraper
