588,265 active members*
6,090 visitors online*
Login Register
EROWA - Banner
EROWA Forum
Laser Engraving / Cutting Machine General Topics > new 80watt - won't engrave in RDworks v8
Results 1 to 12 of 12
    Feb 2017
    HELP. I have a new 80w CO2 Chinese laser. I put a simple text file in RDworks v8 and upload it to the controller/ The output is just a solid burned line no matter the power or speed settings. When I change the file from "Scan" to "Cut" it does burn the text but connects all of the letters together with a burned line. I really think this is a setting problem of some kind, but I have tried everything.
    Frustrated in East Texas
    Apr 2006
    251
    Re: new 80watt - won't engrave in RDworks v8
    Normally you use a bitmap file for engraving. Are you importing a .txt file?
    Nov 2012
    492
    can I see the file your trying to engrave
    Feb 2017
    Quote Originally Posted by Bigbird48 View Post
    Here is a YouTube of the file and what the laser engraveshttps://youtu.be/WobVbhPuDQA
    Nov 2012
    492
    that doesn't tell me anything can you post the file in corel x5 or AI or dxf
    Feb 2017
    The file is just a simple text file in RDWorks that is uploaded directly into the controller.
    Nov 2012
    492
    Fine if we cant see the exact file you can expect no help
    Quote Originally Posted by mskaggs67 View Post
    Mostly the software setting problem, normally the corner engraivng speed or power setting............
    Emily Cheng
    Direct contact Email: [email protected]
    ADD: C-504, In hi Tech square High-Tech Zone, Jinan, Shandong, China
    Tel: +86 0531 88020976
    Mob / Whatsapp: 008618905413376 Skype: G.Weike Emily Cheng
    Web: Fiber laser cutting machine, Metal laser cutting machine - G.Weike www.wklaser.com
    Nov 2012
    492
    Well if he show us the file and the settings we could help him
    Quote Originally Posted by cherrywklaser View Post
    Emily Cheng
    Oct 2015
    96
    Try to engrave on MDF or paper attached file.
    It is circle + square (no fill) and scanned m67 letters. Roughly 1"x2" in size all.
    Polish @ Éire
    Nov 2012
    492
    Cant open can you post as a dxf,cdr or ai file
    Quote Originally Posted by abyss View Post
    Oct 2015
    96
    This file is .rd for mskaggs67 (not for you) to he can put it directly on USB stick and cut/engrave. This way he can check and confirm his machine is ok (if cut/engrave this file properly).
    Polish @ Éire
  1. Lasercut 5.3 downloading to DWin 640 80watt
    By lenlaviolette in forum Laser Control Software
    Last Post: 12-30-2015, 11:43 PM
  2. Replies: 1
    Last Post: 12-30-2015, 08:33 AM
  3. Need Help. Does anyone have Software that wiil work in a POS Chinese 6090 80watt
    By aplus1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-12-2015, 01:13 AM
  4. ust pulled the triger on a G.Wieke LC1290 80Watt
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2013, 03:06 AM
  5. Looking Feed back on WKlaser Model 6090 80Watt
    By lrob in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-06-2010, 07:42 AM
EROWA - Skyscraper
