588,487 active members*
5,035 visitors online*
Login Register
HAINBUCH GMBH - Banner
HAINBUCH GMBH Forum
SPANNENDE TECHNIK
Wooden Clocks > Problem cutting the Escape gear
Results 1 to 5 of 5
    Dec 2009
    20
    Im having a terrible time with the escape gear, even though the gear is faily large 10", the teeth are very sharp at the tips, have tried several different methods of cutting with the same results, tearing, chip out, fuzzing, using .25" baltic birch plywood, .90 upcut bit, running 18-20,000 rpm, have tried slower rpm, faster and slower feed to no avail, the thicker gears, .375 plywood is cutting only fair, no chip out, but still needs excessive sanding, its evident all of you who have built a wooden gear clock have overcome this problem. Please share your knowledge !!
    Sep 2009
    15
    I had that problem when using baltic birch plywood for the escapement, so I now make the escapement out of segmented hardwood, 12 segments 30 deg each about 3-4mm thick I make 2 layers and glue the layers 15deg offset to each other to strengthen the segment joint. I also insert a piece in the center as the points of the segments all meet at the center and are not good enough for an axle. I still use baltic birch plywood for all of the gears. The attached escapement (4inch dia) is straight off the machine with no sanding.
    Dec 2009
    20
    Thanks, Lagore, I was beginning to think no one was going to post a reply to my problem, the escape gear you created is a work of art, thanks again for the information
    May 2012
    33
    I also have had goods success engraving around the gear with a v carve bit set to a 32nd depth.
    Ronnie
    Apr 2013
    But hey thanx for posting!!!
  1. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  2. Escape wheel for wooden gear clock
    By pinhead_mt in forum BobCad-Cam
    Last Post: 03-24-2012, 06:09 AM
  3. Gear cutting on the X3 CNC
    By John S. in forum Benchtop Machines
    Last Post: 12-08-2007, 02:26 AM
  4. Gear cutting
    By watchman in forum MetalWork Discussion
    Last Post: 02-15-2007, 01:12 PM
  5. Why did the smoke escape?
    By obscurity in forum Stepper Motors / Drives
    Last Post: 05-29-2006, 05:34 AM
