https://github.com/MichaelWoodc/LINU...O_using_awlsim
It's highly possible we can use all of the original controls from the earlier machines with linux cnc for non-realtime machining operations.
I've done a lot so far but I'll just go ahead and share a few key things and hopefully get some experienced people interested in collaborating.
The earlier milling machines seem to use Profinet/ profibus or Siemens PLC's. They have current linuxcnc projects for both of those. The problem is simply to modify the existing ones for our machines, then to work on any bugs not only in that but in the preexisting software, and to add support for anything not currently supported in current projects.
Please post here if you'd like to help, or on github, I need to add some collaborators to this
