588,277 active members*
6,301 visitors online*
Login Register
HAINBUCH GMBH - Banner
HAINBUCH GMBH Forum
SPANNENDE TECHNIK
OpenSource Software > DXF2GCODE software "Path Optimization"
Results 1 to 2 of 2
    Dec 2012
    Hello
    M minutes ago installed the DXF2GCODE software.
    I am developing a path optimizer for the holes I produce in CorelDraw, exported as PLT and run through a software I made to convert to raw XY numbers to drill with G41 on a small router we have.
    It is working nice, the optimization is the most simplest possible, just seek the closest hole to be the next in a positional matrix, it works nice, but due the simplicity of it, make some mistakes.
    I knew about the TSP (path optimization) of DXF2GCODE, so I wanted to see it working.
    I used the same Corel image, now with a continues line going trough crazy cris-cross over the holes, exported the line (image) as DXF and open it on DXF2GCODE.
    The image is there, nicely, if I export from DXF2Gcode WITH optimize and shapes, it does not optimize, just export a gcode file exactly in the same sequence of the line sequence in Corel.
    I even checkmarked the "By default enable the TSP..." on Configuration/Output settings, Constrain_xxxx (both), tested all starting point options.
    There are 31 holes (the Corel continuous line change angle in 29 points, plus two extremes), so I setup Max Population to 80 (just in case) and Max iterations: 5000.
    It still doesn't work.
    Can somebody help me to point what is my mistake on DXF2GCODE setup or operation, in order for the optimization to work?
    Does anyone ever used the Path Optimization of DXF2GCODE?
    Thank you,
    Wagner
    Jun 2015
    4171
    Re: DXF2GCODE software "Path Optimization"
    hy, do you still need help ? i can do stuff / kindly
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Bobcad V27 "nc file path" won't stick
    By naa73x in forum BobCad-Cam
    Last Post: 02-19-2016, 06:24 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. selling ""used"" solidworks software
    By DWAS in forum Solidworks
    Last Post: 10-25-2010, 07:14 AM
