588,289 active members*
5,969 visitors online*
Login Register
HAINBUCH GMBH - Banner
HAINBUCH GMBH Forum
SPANNENDE TECHNIK
Other Machine Topics > green horn needing motor help
Results 1 to 8 of 8
    Oct 2018
    20
    I purchased a cnc that was originally built for cutting aluminum and laminated aluminum, with the idea of reconfiguring for my woodworng needs. The seller had purchased it from the original user but had no dea how to make it work. As this thing is greek to me but possbly I can figure it out. I would like to see what is good and what isn't on what I purchased. My question is, can I run some sort of alternative wiring to the plugs on the motors to see if they will actually turn the ballscrew? Thanks, Don
    15362
    Re: green horn needing motor help
    Quote Originally Posted by cpdad93 View Post
    No if you just have a motor (most likely a Stepper Motor or a Servo) you would first need a Drive and a Power supply then a Control, of some kind to run it, Post some Photos of what you have, what you posted tells us nothing, look at the motors for any type of numbers Etc
    Mactec54
    Apr 2004
    5759
    Did it come with a computer? If not, that might be the missing part of the puzzle. Most of these machines require a PC of some sort loaded with control software that sends signals to the motors that tell them how to move.
    Andrew Werby
    Website
    Dec 2003
    24220
    As suggested ! Steppers? Servo's? Make? Model?
    Albert E.
    Oct 2018
    20
    attached are the pictures with numbers etc
    Attached Thumbnails Attached Thumbnails IMG_4533.jpg   IMG_4530.jpg   IMG_4532.jpg   IMG_4534.jpg
    Oct 2018
    20
    posted, thanks
    Dec 2003
    24220
    Albert E.
    Apr 2018
    136
    Well, he did actually post those images. However, CNCZone is choking on them. Its not the fault of anyone in this thread. Images retrieved sister site Industry Arena.
    OK, there is/was a problem with how the server is handling images. I worked around that problem by posting the images to a photohost, and then posting the links to those images above.
    Use the (8) links above, not the "attached image file" below, which I left there for diagnostic purposes.
