588,367 active members*
6,432 visitors online*
Login Register
HAINBUCH GMBH - Banner
HAINBUCH GMBH Forum
SPANNENDE TECHNIK
Machines running Mach Software > Using Mach for a laser
Results 1 to 11 of 11
    6855
    Well not having much luck getting the laser to work off M0 codes or using plasma setting. The only thing that is working is using the z for on off control, BUT that is a pain. When the machine is at the home position and I cycle start the program the z moves down, which in turn turns on the laser. NOT good being that I don't have a z axis, so I have to manually turn on the PSU before the machine starts to cut. Any suggestions?
    Oct 2003
    927
    Hi Paul,
    I suggest you post your questions to http://groups.yahoo.com/group/mach1mach2cnc/messages
    There, Art can guide you to make full use of Mach. AND if you show your needs, Art can incorporate them into Mach.
    You just may be the one to provide insight for Art in adding features specifically for Laser operation.
    Bloy
    6855
    Quote Originally Posted by Bloy2004
    Hi Paul,
    I suggest you post your questions to http://groupyahoo.com/group/mach1mach2cnc/messages
    Bloy
    Thanks Bloy, But no thanks, I refuse to use yahoo, I stopped using that site 3 yrs ago.
    Apr 2005
    421
    just login and set it up as a list server to deliver to your email. then set a filter up on your email proggie to drop them in a folder. Never see Yahoo.
    You can email art directly for support. Link on his website.
    Nov 2004
    118
    Quote Originally Posted by CNCadmin
    HELLO Paul,
    You should beable to use any of the other ouputs to turn on the laser. You can put the code in the M3, M4 and M5 macro's. If you can tell me a little more about it and I can help you with the code.
    I know we can get this to work
    Brian Barker
    www.newfangledsolutions.com
    6855
    Cool, I'm using SheetCam and Mach together. Here is what I need it to do-
    1) turn laser on and off
    2) be able to set the frequency via PWM as my PSU has a TTL
    3) When cycle start, laser stays off during a G00 move
    4) would like for it to go the safe home after the last cut
    Paul:
    Well, the PWM issue shoudl be automatic if Laser Spoindle mode is selected, so I think all you really need to do is make a special Macro to turn it on and off. Since M3 will turn it on automatically, (of course if the code is written for a router, then G0's woudlnt have it runnign anyway..). Actually, depending on how you do the code,you shoudl be OK, if the code is generated with M3's and M5's that turn the lasr on and off to cut entities, then it shodu have no turn on/off issue..
    I woudl set the laser on not to the 2.5D Z, but to the spinlde on/off pin, that woudl make it work fine, you just have to make sure the program is a normal router program with no Z movement at all if you wish. The PWM laser triggers shoudl then be OK, and the laser shoudl only be on when a router would have been. Any reaosn why you set it to turn on by the 2.5d Z signal?
    Art
    www.gearotic.com
    Art Fenerty
    6855
    Thanks Art for you time,
    I'm using the z signal because that is the only one that works, setting it on the spindle pins, does nothing. Even when I press the spindle button the laser will not turn on, I'm sure I'm doing something wrong, but I can figure it out. In the set-up page I select the spindle control and PWM, than I set the pin number that I have the control contented to on my break out board. Manually I press the spindle control button and nothing happens.
    Nov 2004
    118
    There are some settings that you have to set on the ports and pins page. If you would like to send me your XML I will have a look at it and send it back to you
    Brian
    6855
    Quote Originally Posted by Barker806
    Brian
    That would be great! I'll do that today.
