588,513 active members*
5,885 visitors online*
Login Register
HAINBUCH GMBH - Banner
HAINBUCH GMBH Forum
SPANNENDE TECHNIK
Fanuc > Servo amp for Fanuc motor need help matching
Results 1 to 11 of 11
    Feb 2005
    28
    I have an old fanuc servo I would like to use but need to find an appropriate servo amp, motor is:
    40S/2000
    A06B-0583-B065#7000
    Searching the forum I found some fanuc data sheets which say the motor has a high resolution pulse coder 25000p/r but for the high resolution models it does not say whether it is absolute or incremental. Also is the encoder a standard quadrature or fanuc proprietary? Either way where could I find pinouts for it?
    Matching it to the 'original' fanuc amp would be an option but I am not sure how.
    Are there any model number references for fanuc servo amps like for the motors?
    I plan on using Mesa cards and EMC to drive it, the final card will depend on if I can find an analog or pwm amp.
    Thanks.
    Dec 2008
    239
    Mesa cards and EMC
    you can use the similar series of drive , what is the size you are planing for ? what is your interface type?But remember this type of motors and drives are specially designed for CNC machines closed loop circuits , some series like 30 180 and 300 are the open loop controller with the versatility you can use anywhere . My opinion only.
    Quote Originally Posted by paulr4 View Post
    40S/2000
    A06B-0583-B065#7000
    Thanks.
    Feb 2005
    28
    This is a 7kw motor, I would like to have close to full power. Application is basically a turning C-axis so it has to be closed loop. It will have to switch between turning (dumb) and then index or possibly live c axis if the mechanicals are strong enough to work without a brake.
    I am just starting this project and since I already have this motor I would like to use it. My biggest concern is the encoder working with the servo amp. If I have to replace the encoder or get the wrong amp I might as well just get a matched motor/drive combo.
    The final interface will be a mesa card, which one depends on the drive I end up with either analog or pwm
    Dec 2008
    239
    can you please give exact drive and motor number?
    24221
    If using anything but Fanuc drive, the problem is that the commutation is Fanuc proprietary, There is a add-on available to convert the commutation to normal BLDC.
    I have also fitted replacement encoders with comm. tracks.
    I believe you will find that is hi-res differential/incremental for the encoder portion.
    Al.
    Albert E.
    Feb 2005
    28
    Motor is:
    40S/2000
    A06B-0583-B065#7000
    I don't have a drive yet, that is what I am trying to find.
    I looked the at pico systems fanuc converter but it's max resolution is listed as 10k p/r and this endcoder is 25k p/r.
    Changing the encoder does not seem worth it as it will be 1. Lower res encoder, 2. have to buy it and a drive, 3. This motor is only 2k rpm, I would prefer faster.
    I have found some threads on the EMC forum about using HAL to translate fanuc signals to something BLDC can use but I have not seen the actual protocol anywhere
    What I also cannot find is which fanuc drive, there are plenty on ebay with the correct ratings but will they support the encoder?
    Dec 2008
    239
    which fanuc drive
    You can use fanuc drive with externel encoder upto 100000PPR
    the encoder you are planning to use is a incremental or Absolute type of encoder?
    Regards
    Motor is:
    40S/2000
    A06B-0583-B065#7000
    Feb 2005
    28
    I don't know if the encoder is abs or not. Unfortunately the only spec I have is a PDF I got searching the forum, it breaks down all the motor part numbers.
    For all the other encoders it lists absolute or incremental, for the 3 high resolution part numbers (of which this is one -65) it only says 'high resolution pulse coder'
    24221
    How many pins does the MS connector have 17 or 19p? I think you will find it is incremental, get the pin out and do a test.
    Also there should be a number on the encoder itself.
    If it is a 19p MS you may be out of luck.
    Al.
    Albert E.
    Feb 2005
    28
    Unfortunately it is 19pin , so that means absolute encoders? Do you know where to find pinouts? I have not yet taken off the encoder cover, and there is no part no. (other than the motor) on the outside. Thanks.
    24221
    Not sure if it confirms 100%, but usually the 19pin is either absolute or some other format, one of which requires an intermediary unit between encoder and system, IOW non-TTL differential.
    Al.
    Albert E.
  1. Matching the right driver to the right motor
    By mcrLABS in forum Automation Technology Products
    Last Post: 09-11-2011, 05:43 PM
  2. Matching an AC servo to a Driver
    By RP Designs in forum Servo Motors / Drives
    Last Post: 04-10-2011, 07:15 AM
  3. Matching a servo drive to a servo
    By 69owb in forum Servo Motors / Drives
    Last Post: 02-04-2009, 04:00 AM
  4. Matching different drive and motor size
    By kumphanart in forum Servo Motors / Drives
    Last Post: 08-20-2008, 11:02 PM
  5. motor mixing and matching...
    By charleyy in forum DIY CNC Router Table Machines
    Last Post: 09-06-2004, 05:32 AM
