Hi people!
I recently purchased a Deckel FP5 NC (with Dialog 4). Got it to my small shop, plugged it in, made some moves on manual and everything went ok.
However, from time to time the machine would freeze and "V" sign would come up next to the X,Y or Z axes. Made some research and found out that the linear scales had to be cleaned up. I did that, replaced the gaskets, put them back on the machine and now everything seems ok, except for the fact that the machine has lost its reference (Home) position. (If I try to reference the machine on any axis, I only get the highlighted R mark. And that is it.)
What is the procedure for resetting the home position for this machine? (after cleaning the linear scale)
Thank you in advance!
