In the attached pic, there is an oil grove that starts at the end, goes in roughly an inch in 270 degrees and then backs out in 270 degrees. In the pic you can't see the exit, but is 180 degrees from the entrance.
I could write a threading G-code, or use a canned Mach4 threading program to do the inbound groove and then do a second program to do the outbound. But how would one "connect" the grooves together? How does Mach determine at what point in the circumference to start?
Another option would be an inbound G-code followed by an outbound G-code. Then move the tool in the X direction. then do the same in and out G-code. But would the tool start at the same spot like threading?
Thanks for any insight. I guess I need to go experiment.
Dale Grice
