We are Chinese manufactuer of Corner Forming Machine provide customers variety of solution of automatic corner forming service.
It is high efficient corner forming equipment for corner forming such as panel,electric cabinet
door aluminum roof or buckle plate corner forming and so on.
For your flexible Corner Forming Machine ,you can choose different corner shape(Rectangle ,Triangle,Octagon)
For the Rectangle Corner shape ,the R Corner Radius Range from R1.0-R52.
For the Triangle Corner Shape,It is suitable for road/traffic signs industry.
For the Octagon Corner Shape,the maximum bending flange height 30mm.
Cabinet Door Croner Forming Machine
Sheet Metal Corner forming machine is used in the processing of sheet mental corner forming such as cold-rolled plate, aluminum plate, stainless steel plate, copper plate etc.
Widely used in the switching door, cover plate, aluminum single panel curtain wall, switchboard, container cover, household appliances, instruments and other fields.Free spare parts, Online support, Video technical support.
The forming and shearing of the work-piece are processed separately at two stations; the installation of safety light curtain protection makes the production process safer and more user-friendly. Equipment mold gap adjustment is Fuji servo motor control accuracy, adjustment parameters through touch screen settings, Mitsubishi PLC control equipment other actions. The equipment comes with a set of molds, which include forming rollers, forming squares, and cutting tools.
A corner forming machine is a type of equipment used in metalworking and fabrication to create bends, corners, or folds in sheet metal. These machines are designed to handle various materials, including steel, aluminum, and other alloys.
If you are interested in it ,visit our web
www.rizhenmachinery.com
