INDEX
2661
INDEX
2661
INDEX Gearing Experts at GearExpo in Detroit
MarketingINDEX-Werke GmbH & Co. KG Hahn & Tessky on September 22, 2015 at 12:05 PM
Meet us at GearExpo in Detroit from October 20-22, 2015 at Booth 1653 and discover the world of turning and gearing of INDEX!
More done in one.
We show you how to quickly cut spiral bevel gears from bar with the INDEX R Series turn-mill centers. Process gears with front and rear end machining, complete in one setup. Or run as a 2-spindle gear cutting machine.
The INDEX continuous indexing method – which corresponds to the Klingelnberg Cyclo-Palloid® –
produces spiral bevel gears with constant tooth height in a module range of 0.6 to 4 mm
The new bevel gear hobbing package includes specially designed control cycle and four INDEX cutter heads with module-dependent inserts. Shorter cycle times, better geometry and position tolerances with total flexibility.
 Join us at GearExpo!  www.gearexpo.com
Get more information about INDEX bevel gear technology at: www.index-traub.com/gearing
