INDEX
2661
INDEX
2661
INDEX TRAUB expanded CAPTO system
MarketingINDEX-Werke GmbH & Co. KG Hahn & Tessky on November 21, 2014 at 12:55 PM
The advantages of the modular quick-change system INDEX TRAUB CAPTO can be immediately used in combination with compact shank tool holders.
This allows INDEX TRAUB the ability to use the polygon interface on all INDEX and TRAUB machine series.
With INDEX TRAUB CAPTO you will have more flexibility throughout your entire manufacturing process and more stream line solutions for your setup time.
A variety of available quick-change adapters gives each tool holder the ability to universally interface with your equipment. Whether it be collet, weldon, hydraulic expansion or inserts recordings, etc. - you can find the right adapter for your application in our infoshop.
The quality and stability of the INDEX TRAUB CAPTO quick-change system enables a sophisticated machining process while continuing to maintain high quality.
The patented alignment systems and turret interface of INDEX and TRAUB will support you in achieving your quality goals.
For further questions please call us at +49 711 3191-9854 or
by email: [email protected]
