INDEX
2661
INDEX
2661
The innovative turn-mill center INDEX G400
MarketingINDEX-Werke GmbH & Co. KG Hahn & Tessky on July 4, 2020 at 1:00 PM
The innovative turn-mill center for high-performance machining of large workpieces
Turning and milling – complete machining in new dimensions
Machine highlights INDEX G400 / INDEX G420
Your benefits
  • Identical main and counter spindles with spindle clearance D 102 mm or D 120 mm
  • Chuck D 315 mm (optionally up to D 400 mm)
  • Tool stock for up to 139 tools
  • Sophisticated working area concept for turning lengths up to 1,600 mm and variable
  • machining options
  • High thermal and mechanical stability
  • High dynamic response (rapid traverse rate up to 50 m/min)
  • Chip conveyor can be used on the left and right
https://www.index-traub.com/en/products/turn-mill-centers/index-g400-index-g420/
