603,405 active members*
3,121 visitors online*
Login Register
INDEX Forum
Fadal > VMC 4020 start up issues. Help!
Results 1 to 9 of 9
    Feb 2014
    Unhappy VMC 4020 start up issues. Help!
    My problem is that I switch the power on, then hit the "start" button but I cannot get the table and spindle as well as the controller to power up. The machine starts humming like it is powered up but these components do not turn on. Any one else have an issue similar to this. I have checked fuses and connections but I cannot seem to get it to start up. I am leaning towards the start button being bad and maybe not contacting.
    So just wanted to throw this out there and see if anyone had a similar issue who could point me in the right direction. Thanks in advance. Also sorry if this has been posted before I didn't have time to search through the archives.
    Jan 2004
    3154
    There is a "PC type" power supply in the side panel that may be toast
    www.integratedmechanical.ca
    Feb 2014
    That seems to be it. got power going in, nothing coming out. Thanks!!
    Mar 2008
    684
    I will guess you've checked that the button is good...
    Otherwise, on my fadals, I've traced back problems like this to the solid state relays.
    Good luck.
    Mar 2014
    22
    Re: VMC 4020 start up issues. Help!
    call FADAL at 818-727-2100.. they will have the answer and the part for your problem
    Apr 2008
    1577
    This sounds like a problem that we had with our 5020 for years. Try it at your own risk (and I have no idea why I did it the first time) but hold the green button down when you throw the knife switch. That was the only way to turn the machine on for several years until our Fadal repair guy finally found the problem. I would love to remember what it was that he replaced but I was on vacation when the fix was discovered. If this solves your problem, I will dig out our invoices to help you find the fix.
    Apr 2014
    9
    If you are not getting any of the Red LEDs blinking on the boards in the control rack then check if the power supply is putting out 5VDC and + and - 12VDC. If no VDC out then the power supply is toast.
    Sep 2014
    @SBC Cycle, that worked for us. Can you remember the true fix for the problem?
    Thanks!
    Aug 2014
    8
    Sounds like the 'brown out" circuit is acting up?
  1. Fadal 4020 Not Aligning Cold Start
    By homchz in forum DNC Problems and Solutions
    Last Post: 09-19-2022, 08:25 PM
  2. Replies: 10
    Last Post: 03-17-2015, 03:52 PM
  3. EZ-Trak DX II Start-up issues
    By shamusmtb in forum Bridgeport / Hardinge Mills
    Last Post: 08-04-2010, 08:29 PM
  4. 4896 issues... where to start... (Long)?
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 06-11-2010, 01:36 AM
  5. 4020 fadal cant get past "Cold Start"
    By chipsahoy in forum Fadal
    Last Post: 03-08-2006, 01:29 AM
