Yesterday I made the first test cuts.
Y axis diagonal leg braces were added. It shook a lot when moving the gantry. Rapids are comfortably 250 IPM, i could probably push higher,
Getting Mach 4 and ESS working well was a bit of an adventure. Here are some of the things I learned along the way:
The first thing is getting the PC to reliably talk to the ESS. In the ESS config if after restarting , you don't see the IP address for ESS, they are not communicating, the value in the config screen once Entered is blank until they communicate. If in doubt look in the Mach config file to see the IP address is really there. If you can ping the ESS successfully but they are still not communicating, it is likely windows firewall getting int eh way. I had more trouble getting it to work with Win 7 (temporary test) vs XP - the normal CNC PC.
The order of setup is important. ESS I/O assignment and naming must be done before the Mach I/O assignment. It may seem obvious to an experienced Mach user but was not to me, I assumed the plugin assignments would come second.
When making your initial tests to see if things can work incrementaly, you really have to be extra careful as you can easily destroy things. In my case 2 D connectors, 2 microswitches buried in the middle of the Z carriage, and a router bit). Impressively the Leadshine MX4660 stepper driver survived the connector crunch and short . Conversely it does NOT like having motors unplugged and plugged in while powered on. It gets into some weird oscillation (lots of noise, no motion). The MX4600 does normally make some noise via the motors at rest. It must be switching the holding current some how. I have not hooked up a scope to see what is going on, but is s now part of the background noise
Leg bracing is important. in this case there is a lot of mass moving around with the Gantry (> 150lbs.). Moving along the x-axis was fine, but Y direction would oscillate pretty badly. With one more diagonal per leg it is nice and quiet now with minimal wiggling.I had to wait for the welding work until it warmed up a bit here in the frozen north.
So here is the second run:
The bit was just a 2 flute straight bit - waiting for the right ones to come.
And some more photos:
Attachment 273552
Attachment 273554
Attachment 273556
Attachment 273558
Now I am moving the electronics to a permanent enclosure, finishing the limit and home switch mounting and wiring and then hooking up the cooling loop.
