586,103 active members*
3,557 visitors online*
Login Register
INDEX-Werke // INDEX TRAUB Forum
CNC Machine Related Electronics > how to wire this encoder to interface with a centroid allinone dc for MPG?
Results 1 to 6 of 6
    Feb 2004
    84
    I'm doing a centroid retrofit with allinone DC controller and happen to have this mpg handwheel from a machine that got scrapped. I'd like to use it for a pendant for my retrofit. Is there a way to use this unit? Doesn't have a few of the connections the controller requires- only has the 4 wires you can see on the back- +,-,A, and B....
    See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
    Apr 2005
    304
    Re: how to wire this encoder to interface with a centroid allinone dc for MPG?
    Just add one MC3487N QUADRUPLE DIFFERENTIAL LINE DRIVER or similar.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Feb 2004
    84
    Is there a ready made, cheap, screw terminal module that will get the job done?
    Apr 2005
    304
    As far as I know, there is no ready made module. It can be easy made if you are willing to make your own PCB, or if you have someone that can make it for you.
    Just designed one in 10 minutes
    Feb 2004
    84
    Someone just sent me a link to one, cnc4pc model c72 should do the job I think. Thanks though!
    Nov 2012
    1267
    Yes, the C72 module will work for this. It will convert the single-ended signals (A and B) to differential signals (A+/A- and B+/B-).
  1. Centroid CPU10 encoder connections - Replacing Servo3IO with Acorn
    By SEK22Hornet in forum Centroid CNC Control Products
    Last Post: 05-30-2020, 01:46 AM
  2. Encoder/servo selection for a Robotool centroid retrofit
    By WesM in forum Servo Motors / Drives
    Last Post: 04-26-2020, 02:52 PM
  3. Centroid OAK board keyboard interface question
    By MrBean_pm in forum Centroid CNC Control Products
    Last Post: 05-13-2018, 01:45 PM
  4. Need some help with a Centroid M400 - CPU7P3 - Z axis encoder connection bad.
    By glbreil in forum Centroid CNC Control Products
    Last Post: 10-13-2013, 02:32 PM
  5. Interface board Rodgers board/ Romaxx Encoder Interface.
    By Ark1 in forum Wood Lathes / Mills
    Last Post: 03-23-2013, 10:57 PM
