TOOL FACTORY
303
TOOL FACTORY
303
MR290 - the new square shoulder cutter
MarketingTOOL FACTORY Cutting Tool Solutions GmbH on January 14, 2020 at 11:46 AM
Our new square shoulder cutter MR290 convinces with high rotation and axial run-out accuracy due to high precision of the insert pockets and ground indexable inserts. You achieve high cost efficiency due to double-sided inserts with six cutting edges. It can be used with a wide range of materials and is ideal for slot, shoulder, face and plunge milling as well as roughing and finishing. You achieve a high level of process reliability through optimum cooling (air/ coolant) through IC holes and thick, stable indexable inserts.
In our latest video you can see the MR290 in operation: https://www.youtube.com/watch?v=5HUK1Vkbw_4
