TOOL FACTORY
303
TOOL FACTORY
303
No compromises: Expect the highest metal removal rate
MarketingTOOL FACTORY Cutting Tool Solutions GmbH on October 1, 2020 at 11:40 AM
With our innovative five-edged end mill 35502, you can make your machining even more efficient. Comparisons with competitor tools have shown that the strengths of our 35502 are its high metal removal rate and tool life - when machining in C45, the metal removal rate was increased by approx. 30% compared to the reference tool, and this with significantly longer tool life.
A further advantage: with just one tool you can optimally machine almost any machining task in a wide range of materials. Because: this all-rounder is suitable for full slot milling, roughing and finishing, as well as for trochoidal machining in all steel grades.
