TOOL FACTORY
303
TOOL FACTORY
303
Our 35502 convinces with the highest metal removal rate and its universal applicability
MarketingTOOL FACTORY Cutting Tool Solutions GmbH on February 4, 2021 at 10:44 AM
Did you know ...?
...that with our new solid carbide HPC high-performance end mill 35502 you only need one tool for almost every machining task and optimum results?
The end mill achieves a 30 % higher metal removal rate and can be used in all types of steel, such as heat-treatable, tool and stainless steels. Due to its newly developed cutting edge geometry, it is suitable for full flute milling, roughing and finishing up to 2xD into solid, as well as for trochoidal machining. Due to the high surface qualities, following process steps can be avoided and the costs per part can be significantly reduced.
Check out our 35502 in action in our latest video.
https://www.youtube.com/watch?v=gHX8DA_ky2k
