WFL Millturn Technologies
266
266
M175 MILLTURN - Dynamic and force combined
Quality and size in a new dimension Bigger, stronger, faster - with the latest M-series product - the M175 MILLTURN - WFL is launching a new giant of complete machining. This contains significant innovations, ensures the highest precision and an advantageous versatility for customer requirements. The new turning-boring-milling unit offers a max. swing diameter of 1750mm and can accommodate up to 15.000kg heavy workpieces very stable due to the new, large-sized bed guideway for steady rest and tailstock.
The turning-boring-milling unit has an X-stroke of 1620mm and a Y-stroke of 1100mm and can therefore be used uncompromisingly and universally, e.g. for deep radial machining. Due to the large volume box structure of the turning-boring-milling unit cross slide with a very wide bed guide base and multiple arrangement of ground gliding guideways
in the X- and Z-axis, the tool carrier system has a particularly high stability. This massive and powerful construction is combined with proven main and milling spindle systems, whose 113kW and 58kW drives are extremely reliable in their performance.
Facts:
- Very stable construction
- Deep radial machining possible
- 58kW milling capacity
- 113kW main spindle power
- Max. workpiece weight 15.000kg
- Y-stroke 1100mm
- X-stroke 1620mm
- Max. turning diameter 1750mm
- Specially configured machine on customer request
DOWNLOAD COMPLETE ARTICLE
Responsible for the content of this press release: WFL Millturn Technologies GmbH & Co. KG
