WFL Millturn Technologies
266
266
M80 MILLTURN - Unlimited variety
Highlights and advantages of the machine
One million possibilities
WFL’s modular system allows for huge variant diversity. The machine concept is based on minimised distances between work piece and tool to the slide rails and widest possible guideway distances. This results in ideal conditions regarding stability and geometries.
A cut above the rest
The turning boring milling unit is the core module of the M80 MILLTURN. It is designed for heavy machining in terms of performance and dimensioning of the components. Well proven components such as the prismatic tool changer or the U-axis can be used on the M80 as well. Moreover, further machining units can be installed at an additional  upper slide if required. All centre distances, except 1000mm, are also available in a counter spindle version. An additional tool turret can be offered for further productivity enhancement if required. Due to the innovative arrangement of the guide ways, there is no need for telescopic covers. This ensures a perfect chip flow. The minimum distance between steady rest slide and tailstock or two adjacent steady rest slides is merely 50mm. For this reason, many clamping situations can be realised much easier than in conventional machines. Steady rest slide and tailstock are equipped with NC-drives in the standard version already. They can therefore be positioned independently or simultaneously if necessary.
Rigid, precise and flexible
The tool magazine is easily accessible from the front of the machine. It is especially compact, stable and almost maintenance- free. The high dynamic tool changer is driven by a gear rack and has linear axes only. Even tools up to 35kg can be changed safely and quickly.
Focus on technology know-how
The M80 MILLTURN has a virtually unlimited range of machining possibilities. It can be used for turning, boring and milling as well as other technologies such as circular milling, turnmilling, B axis turning, deep hole drilling, ID-turning, hobbing and many more boring and milling operations.
Fields of application
The M80 MILLTURN provides best performance for suppliers in the aerospace industry as well as manufacturers of highly accurate and complex work pieces in industries such as mechanical engineering, engine manufacturing, energy technology and hydraulics. In fact, practically any geometric contour can be machined efficiently and with maximum precision by means of a MILLTURN.
Read similar articles
Responsible for the content of this press release: WFL Millturn Technologies GmbH & Co. KG
