586,071 active members*
3,883 visitors online*
Login Register
GMN Blog
Precision by tradition
Ball bearings for navigation measurement equpiments
August 2020
25
Author: GMN
Company: GMN Paul Müller Industrie GmbH & Co. KG
GMN has been involved in the manufacture of special bearings for navigation systems, starting our company’s long tradition in measurement equipment.
PRECISION GUARANTEED
GMN bearings and bearing units for measurement equipment provide the highest precision and stable quality with low installation space and weight. Products include:
  • Rotary encoder
  • Navigation systems (e.g. gyro compass)
  • Probes of coordinate measuring systems
The challenges for measurement technology:
  • System accuracies up to
  • Low, non-repeatable beat (NRR)
  • High system rigidity
  • High tuning accuracy
  • Low starting and running friction torque
  • Compact dimensions (thin-section bearing)
  • Low system weight (materials, construction)
  • Absolute cleanliness during assembly
OPTIMIZED ENGINEERING
Development and manufacturing products and solutions for measurement equipment places significant requirements on design, manufacturing, measurement systems and component handling. 100% inspection of individual parts and total systems are a significant condition for constant quality and the highest precision.
Significant performance criteria are:
  • Very compact designs using GMN’s manufacturing technologies for thin-walled bearings
  • Innovative, weight-saving compound techniques
  • Assembly in laminar flow hoods
GMN bearings and bearing units for measurement equipment provide the highest precision and stable quality with low installation space and weight. Products include: Navigation systems (such as gyro compasses), rotary pulse generators, probes for coordinate measurement systems.
KL_SL_Navigation_BSP1_935x550
FLANGE BEARINGS FOR POSITIONING SYSTEMS
  • Special design (thin-walled, double-row)
  • Special cage (toroid)
  • Very low, specified starting torque
  • Constant, specified friction torque
  • Very high running accuracy
  • Highest tuning accuracy
  • Material: stainless steel (AISI 440 C)
KL_SL_Navigation_BSP2_935x550
BEARINGS FOR ROTARY SENSORS
As a single bearing with a special design (dimensions, cage, sealing) …
  • Thin-ring bearings (compact design space)
  • Bearings paired and matched
  • Lifetime lubrication
… fully assembled unit (bushing and bearing)
  • Bushing material: Steel
KL_SO_NAV_BSP3_935x550
BEARINGS FOR FEELER HEADS IN COORDINATE MEASUREMENT MACHINES
  • Fully assembled unit (bushing and bearing)
  • High stiffness
  • Bushing material: Aluminum
