LACH DIAMANT, the diamond and CBN tool manufacturer, launches its new web presence in modern design. Visitors to the website can now benefit from an extensive content focusing on LACH DIAMANT solutions for a wide range of applications.Go to press info
2021-11-05
PCD Monoblock milling cutter »dia-compact« for the economical processing of Aluminium and Composite
Already in 2019, on the occasion of the EMO exhibition, LACH DIAMANT wrote „the trend in milling is towards Monoblock“– or, in other words, to “renounce“ profitably the use of cartridge milling cutters. The PCD-Monoblock is, in direct comparison with cartridge milling cutters, immediately ready for use – without time-consuming adjustment of the cutting edges needed.Go to press info
2021-11-05
Diamond fever at LACH DIAMANT…
But never fear please and …not to be taken literally.
The LACH DIAMANT staff members and their superior diamond and CBN tools and grinding wheels are raring to go.Go to press info
2021-11-05
With diamond-lapped skate blades on course for success
In 2012 it was Felix Rijhnen whom LACH DIAMANT could congratulate for his successes in the second German skating championships in Berlin.
In the current season we will keep our fingers crossed for Ole Jeske who also made the leap into the squad of the national speed skating team.Go to press info
2021-01-26
A feature that turns heads: The continuous full-LED rear light of the new Polestar 2
An innovation manufactured with LACH DIAMANT precision tools
Go to press info
2020-11-12
»CBN-Duo-power« – „Turning instead of grinding“
Turning hardened steel with newly developed CBN-inserts
Already in 1974 the diamond tool manufacturer in Hanau achieved a technological breakthrough in machining hardened steels with a hardness starting from 58-60 Rockwell (HRc).
Go to press info
2020-08-20
LACH DIAMANT expands Sharpening and Grinding Service for Diamond-wood, -plastic tools and for cuttin
As of now, LACH DIAMANT, well-known pioneer in the field of Diamond Tools, offers its expanded machine sharpening capacities for the sharpening service of Diamond Tools for the furniture- and composite-industry as well as for the automotive industry.Go to press info
2020-08-10
LACH DIAMANT recommends: Re-sharpening Service for PCD Tools
LACH DIAMANT‘s efficiency concept for high performance machining tools
Now of all times, a reliable and fast service is needed to minimise costs – resources must be saved, and inventories must be kept as manageable as possible.
Go to press info
2020-07-14
PCD chip breaker »IC-plus« world’s best – process reliable turning of aluminium alloys
… so soberly it can be read in a catalogue of LACH DIAMANT, the manufacturer of diamond tooling since 1922. Today, in 2020, it is no longer a secret that with the development of polycrystalline chip breakers, which started almost 25 years ago, LACH DIAMANT has accomplished a pioneering feat which ultimately came to perfection in the type »IC-plus« world’s best. Go to press info
2020-07-02
LACH DIAMANT presents: PCD- and CBN-tipped engraving tools for the stamping technology sector
PCD- and CBN-tipped engraving tools for the stamping technology sector, the packaging and printing industry
Another product from LACH DIAMANT Germany - highly precise and wear-resistant.
Go to press info
2020-04-20
LACH DIAMANT will exhibit … (Provisional) Exhibition Dates 2020
The Corona-Virus is muddling up our schedule, too
Go to press info
2020-04-02
„Ideas are still sparkling”
The Hanau entrepreneur Horst Lach celebrates his 80th birthday
On his 80th birthday, April 3, 2020, Horst Lach actually wanted to take a vacation and celebrate this special day together with his family, however, the Corona virus changed his plans.
Go to press info
2020-03-03
LACH DIAMANT presents at AMB in Stuttgart: DragonFly makes Tooth-Face Grinding more efficient
The newly developed diamond grinding wheel for the tooth-face grinding of diamond grinding wheels provides supreme process reliability and stabilityGo to press info
2020-03-02
LACH DIAMANT presents at AMB in Stuttgart Diamond-coated Wear Parts in Series Manufacturing
LACH DIAMANT presents at AMB 2020 in Stuttgart
Long since, diamonds – preferably polycrystalline synthetic diamonds (PCD) – have been proven superior to carbide in machining.
Go to press info
2020-02-28
New at GrindTec: The »Dia-2200-Mini«, now also for diamond tools with extreme axis angles up to 80°
LACH DIAMANT at GrindTec Augsburg – Hall 1, Stand 1076
Go to press info
2020-02-27
LACH DIAMANT at GrindTec »contour-profiled« Dia and CBN Grinding Wheels Revolutionize Deep Grinding
LACH DIAMANT at GrindTec Augsburg:
»contour-profiled« Diamond and CBN Grinding Wheels Revolutionize Deep Grinding
Go to press info
2020-02-27
LACH DIAMANT presents at GrindTec - Dressing and Profiling of Grinding Wheels
LACH DIAMANT presents at GrindTec Augsburg – Hall 1, Stand 1076
The LACH DIAMANT Programme from Tradition to Progress
Go to press info
2020-02-12
LACH DIAMANT at GrindTec in Augsburg from March 18th to March 21st, 2020
LACH DIAMANT at GrindTec in Augsburg from March 18th to March 21st, 2020 – Hall 1, Stand 1076 Let’s conquer the hardest of all things – DIAMONDGo to press info
2019-12-09
50 Years Borazon™ – CBN Grinding Wheels … and another Anniversary for Pioneer LACH DIAMANT
In 1969, during the spring tradefair in Hanover, LACH DIAMANT was the first manufacturer worldwide to demonstrate the grinding of HSS and high-alloy steel on a tool grinding machine
Go to press info
2019-11-04
LACH DIAMANT invites to productronica, Munich, November 12th – 15th, Hall B3 Stand 340 PCB Circuit
PCB Circuit Boards
Cutting – Scoring – Milling with superior diamond and solid carbide tools.
Go to press info
2019-10-15
Diamond Fever at the LACH DIAMANT Stand during EMO in Hanover LACH DIAMANT – Tradition you can touch
Long, long ago, the natural diamond grinding facility
for jewellery diamonds, founded by Jakob Lach in
1922, employed up to 600 diamond grinders in
Hanau, Germany, and the surrounding area.
Go to press info
2019-10-15
Diamond Fever at the LACH DIAMANT Stand during EMO in Hanover »Dia-Fliese-perfect« as one example o
Perfectly imitates the tip of a natural diamond – precise – diamond saving – simply perfect for repeatable dressing of conventional dressing wheels.
»Dia-Fliese-perfect« is more than a diamond-dressing plate – a development of high-tech tool manufacturer LACH DIAMANT with headquarters in Hanau, Germany.
Go to press info
2019-09-23
LACH DIAMANT invites to Productronica Munich
from November 12th- 15th, 2019
Since productronica 1977 – for more than 40 years – LACH DIAMANT has been manufacturing diamond and carbide tools for cutting, scoring, sawing and milling of all circuit boards and composite materials and is rightly seen as a pioneer in this industry as well.
Go to press info
LACH DIAMANT revolutionizes deep-feed grinding
Just take: a special metal bonding agent plus the spark erosion procedure EDG-plus®-“sparkerosion grinding” discovered in 1978.
The result are metal-bond diamond- and CBN grinding wheels with or without profile – concave or convex, which outperform all previous results in stock removal rate and tool life.Go to press info
2019-08-08
New at EMO
New at EMO
The “World’s best” PCD Chipbreaker and Chip Guide Step for process-reliable Turning of Aluminium Alloys – the Cost KillersGo to press info
2019-08-05
LACH DIAMANT presents at EMO in Hanover
50 years of Grinding with CBN-BorazonT
A quantum leap which revolutionized the grinding of hardened steels.
Go to press info
2019-07-29
LACH DIAMANT at EMO in Hanover
Efficient Machining of Aluminium:
The trend in milling is towards PCD monoblock…
Go to press info
2019-07-24
LACH DIAMANT presents at EMO 2019
PCD Diamond Drill
Perfect for Green Carbide and Green Ceramics
More detailed information from your LACH DIAMANT consultant – and of course during your visit at EMO – hall 4, stand D40
Go to press info
2019-07-23
LACH DIAMANT Sites Hanau and Lichtenau near Chemnitz
Remain ISO-certified until July 2022
The South division of the Technical Inspection Agency confirmed compliance with
ISO 9001: 2015 and ISO 14001: 2015
at both sites.Go to press info
2019-04-15
DragonFly sets new standards for tool grinding shops. This innovative grinding wheel provides highe
This innovative grinding wheel provides highest precision and efficiency for machining carbide-tipped saws.
Go to press info
2019-02-25
LACH DIAMANT at EMO in Hanover - Dressing and Profiling of Grinding Wheels
Dressing and Profiling of Grinding Wheels from Single-Point Diamond Dresser to Precision Dressing RollGo to press info
This website uses cookies
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
