586,036 active members*
4,437 visitors online*
Login Register
LACH DIAMANT - Banner
LACH DIAMANT
News
2021-11-05 3…2…1…LAUNCH!
3…2…1…LAUNCH!
LACH DIAMANT, the diamond and CBN tool manufacturer, launches its new web presence in modern design. Visitors to the website can now benefit from an extensive content focusing on LACH DIAMANT solutions for a wide range of applications. Go to press info
2021-11-05 PCD Monoblock milling cutter »dia-compact« for the economical processing of Aluminium and Composite
Already in 2019, on the occasion of the EMO exhibition, LACH DIAMANT wrote „the trend in milling is towards Monoblock“– or, in other words, to “renounce“ profitably the use of cartridge milling cutters. The PCD-Monoblock is, in direct comparison with cartridge milling cutters, immediately ready for use – without time-consuming adjustment of the cutting edges needed. Go to press info
2021-11-05 Diamond fever at LACH DIAMANT…
But never fear please and …not to be taken literally. The LACH DIAMANT staff members and their superior diamond and CBN tools and grinding wheels are raring to go. Go to press info
2021-11-05 With diamond-lapped skate blades on course for success
In 2012 it was Felix Rijhnen whom LACH DIAMANT could congratulate for his successes in the second German skating championships in Berlin. In the current season we will keep our fingers crossed for Ole Jeske who also made the leap into the squad of the national speed skating team. Go to press info
2021-01-26 A feature that turns heads: The continuous full-LED rear light of the new Polestar 2
A feature that turns heads: The continuous full-LED rear light of the new Polestar 2 An innovation manufactured with LACH DIAMANT precision tools Go to press info
2020-11-12 »CBN-Duo-power« – „Turning instead of grinding“
»CBN-Duo-power« – „Turning instead of grinding“ Turning hardened steel with newly developed CBN-inserts Already in 1974 the diamond tool manufacturer in Hanau achieved a technological breakthrough in machining hardened steels with a hardness starting from 58-60 Rockwell (HRc). Go to press info
2020-08-20 LACH DIAMANT expands Sharpening and Grinding Service for Diamond-wood, -plastic tools and for cuttin
As of now, LACH DIAMANT, well-known pioneer in the field of Diamond Tools, offers its expanded machine sharpening capacities for the sharpening service of Diamond Tools for the furniture- and composite-industry as well as for the automotive industry. Go to press info
2020-08-10 LACH DIAMANT recommends: Re-sharpening Service for PCD Tools
LACH DIAMANT recommends: Re-sharpening Service for PCD Tools LACH DIAMANT‘s efficiency concept for high performance machining tools Now of all times, a reliable and fast service is needed to minimise costs – resources must be saved, and inventories must be kept as manageable as possible. Go to press info
2020-07-14 PCD chip breaker »IC-plus« world’s best – process reliable turning of aluminium alloys
… so soberly it can be read in a catalogue of LACH DIAMANT, the manufacturer of diamond tooling since 1922. Today, in 2020, it is no longer a secret that with the development of polycrystalline chip breakers, which started almost 25 years ago, LACH DIAMANT has accomplished a pioneering feat which ultimately came to perfection in the type »IC-plus« world’s best. Go to press info
2020-07-02 LACH DIAMANT presents: PCD- and CBN-tipped engraving tools for the stamping technology sector
PCD- and CBN-tipped engraving tools for the stamping technology sector, the packaging and printing industry Another product from LACH DIAMANT Germany - highly precise and wear-resistant. Go to press info
2020-04-20 LACH DIAMANT will exhibit … (Provisional) Exhibition Dates 2020
LACH DIAMANT will exhibit … (Provisional) Exhibition Dates 2020 The Corona-Virus is muddling up our schedule, too Go to press info
2020-04-02 „Ideas are still sparkling”
The Hanau entrepreneur Horst Lach celebrates his 80th birthday On his 80th birthday, April 3, 2020, Horst Lach actually wanted to take a vacation and celebrate this special day together with his family, however, the Corona virus changed his plans. Go to press info
2020-03-03 LACH DIAMANT presents at AMB in Stuttgart: DragonFly makes Tooth-Face Grinding more efficient
LACH DIAMANT presents at AMB in Stuttgart: DragonFly makes Tooth-Face Grinding more efficient The newly developed diamond grinding wheel for the tooth-face grinding of diamond grinding wheels provides supreme process reliability and stability Go to press info
2020-03-02 LACH DIAMANT presents at AMB in Stuttgart Diamond-coated Wear Parts in Series Manufacturing
LACH DIAMANT presents at AMB 2020 in Stuttgart Diamond-coated Wear Parts in Series Manufacturing Long since, diamonds – preferably polycrystalline synthetic diamonds (PCD) – have been proven superior to carbide in machining. Go to press info
2020-02-28 New at GrindTec: The »Dia-2200-Mini«, now also for diamond tools with extreme axis angles up to 80°
LACH DIAMANT at GrindTec Augsburg – Hall 1, Stand 1076 New at GrindTec: The »Dia-2200-Mini«, now also for diamond tools with extreme axis angles up to 80° Go to press info
2020-02-27 LACH DIAMANT at GrindTec »contour-profiled« Dia and CBN Grinding Wheels Revolutionize Deep Grinding
LACH DIAMANT at GrindTec Augsburg: »contour-profiled« Diamond and CBN Grinding Wheels Revolutionize Deep Grinding Go to press info
2020-02-27 LACH DIAMANT presents at GrindTec - Dressing and Profiling of Grinding Wheels
LACH DIAMANT presents at GrindTec Augsburg – Hall 1, Stand 1076 Dressing and Profiling of Grinding Wheels The LACH DIAMANT Programme from Tradition to Progress Go to press info
2020-02-12 LACH DIAMANT at GrindTec in Augsburg from March 18th to March 21st, 2020
LACH DIAMANT at GrindTec in Augsburg from March 18th to March 21st, 2020 – Hall 1, Stand 1076 Let’s conquer the hardest of all things – DIAMOND Go to press info
2019-12-09 50 Years Borazon™ – CBN Grinding Wheels … and another Anniversary for Pioneer LACH DIAMANT
50 Years Borazon™ – CBN Grinding Wheels … and another Anniversary for Pioneer LACH DIAMANT In 1969, during the spring tradefair in Hanover, LACH DIAMANT was the first manufacturer worldwide to demonstrate the grinding of HSS and high-alloy steel on a tool grinding machine Go to press info
2019-11-04 LACH DIAMANT invites to productronica, Munich, November 12th – 15th, Hall B3 Stand 340 PCB Circuit
LACH DIAMANT invites to productronica, Munich, November 12th – 15th, Hall B3 Stand 340 PCB Circuit Boards Cutting – Scoring – Milling with superior diamond and solid carbide tools. Go to press info
2019-10-15 Diamond Fever at the LACH DIAMANT Stand during EMO in Hanover LACH DIAMANT – Tradition you can touch
Long, long ago, the natural diamond grinding facility for jewellery diamonds, founded by Jakob Lach in 1922, employed up to 600 diamond grinders in Hanau, Germany, and the surrounding area. Go to press info
2019-10-15 Diamond Fever at the LACH DIAMANT Stand during EMO in Hanover »Dia-Fliese-perfect« as one example o
Perfectly imitates the tip of a natural diamond – precise – diamond saving – simply perfect for repeatable dressing of conventional dressing wheels. »Dia-Fliese-perfect« is more than a diamond-dressing plate – a development of high-tech tool manufacturer LACH DIAMANT with headquarters in Hanau, Germany. Go to press info
2019-09-23 LACH DIAMANT invites to Productronica Munich
Productronica Munich from November 12th- 15th, 2019 Since productronica 1977 – for more than 40 years – LACH DIAMANT has been manufacturing diamond and carbide tools for cutting, scoring, sawing and milling of all circuit boards and composite materials and is rightly seen as a pioneer in this industry as well. Go to press info
2019-09-23 LACH DIAMANT revolutionizes deep-feed grinding
LACH DIAMANT revolutionizes deep-feed grinding Just take: a special metal bonding agent plus the spark erosion procedure EDG-plus®-“sparkerosion grinding” discovered in 1978. The result are metal-bond diamond- and CBN grinding wheels with or without profile – concave or convex, which outperform all previous results in stock removal rate and tool life. Go to press info
2019-08-08 New at EMO
New at EMO
New at EMO The “World’s best” PCD Chipbreaker and Chip Guide Step for process-reliable Turning of Aluminium Alloys – the Cost Killers Go to press info
2019-08-05 LACH DIAMANT presents at EMO in Hanover
LACH DIAMANT presents at EMO in Hanover 50 years of Grinding with CBN-BorazonT A quantum leap which revolutionized the grinding of hardened steels. Go to press info
2019-07-29 LACH DIAMANT at EMO in Hanover
LACH DIAMANT at EMO in Hanover Efficient Machining of Aluminium: The trend in milling is towards PCD monoblock… Go to press info
2019-07-24 LACH DIAMANT presents at EMO
LACH DIAMANT presents at EMO 2019 PCD Diamond Drill Perfect for Green Carbide and Green Ceramics More detailed information from your LACH DIAMANT consultant – and of course during your visit at EMO – hall 4, stand D40 Go to press info
2019-07-23 LACH DIAMANT Sites Hanau and Lichtenau near Chemnitz
LACH DIAMANT Sites Hanau and Lichtenau near Chemnitz Remain ISO-certified until July 2022 The South division of the Technical Inspection Agency confirmed compliance with ISO 9001: 2015 and ISO 14001: 2015 at both sites. Go to press info
2019-04-15 DragonFly sets new standards for tool grinding shops. This innovative grinding wheel provides highe
DragonFly sets new standards for tool grinding shops. This innovative grinding wheel provides highest precision and efficiency for machining carbide-tipped saws. Go to press info
2019-02-25 LACH DIAMANT at EMO in Hanover - Dressing and Profiling of Grinding Wheels
Dressing and Profiling of Grinding Wheels from Single-Point Diamond Dresser to Precision Dressing Roll Go to press info
