586,538 active members*
3,003 visitors online*
Login Register
ROEMHELD
News
Your solution provider in clamping and handling technology
2024-04-30 New: Rail-Guided Die Changing Table for Simple, Safe and Fast Transport of Loads Up to 40 Tonnes
ROEMHELD announces the new, rail-guided RWS die changing table for transporting heavy dies and moulds. The innovative solution is available in three versions for loads of up to 15 tonnes, 25 tonnes, or 40 tonnes per die. Go to press info
2023-07-21 EMO: Flexible set-up & automation as well as compact, highly adaptable clamping elements & sensors
ROEMHELD will present solutions and components for production automation as well as adaptable clamping technology for the flexible set-up of workpieces at the EMO trade fair in Hanover, Germany. Go to press info
2022-09-01 ROEMHELD at the AMB 2022
Workholding technology with sensor technology for digitalisation, automation and flexibilisation. Premiers: Swing clamp with integrated pneumatic sensing, HILMA.ASH automation system and "balance" clamping systems for distortion-free workholding Go to press info
2022-09-01 ROEMHELD at the Euroblech: The new pull-push system facilitates die and mould changes
Tight cycle times, maximum efficiency: Where forming presses and punches are at work, the entire process chain is trimmed for maximum output. But with decreasing batch sizes, the number of interruptions due to die or mould changes is increasing. How to handle these efficiently will be shown by ROEMHELD at the Euroblech from October 25 to 28 in Hall 27 at Stand K65. Go to press info
2022-02-15 ROEMHELD: New mobile die changing consoles with a load up to 50 t for sheet metal forming
ROEMHELD has introduced a new manually movable changing console for dies up to 50 t weight. The space-saving novelty extends the company’s comprehensive range of components for set-up time optimisation in sheet metal forming. It is designed for all users who want to change forming dies of all weight classes in a time and force-saving way, for example, automotive manufacturers and their suppliers. Go to press info
2021-08-25 ROEMHELD at Blechexpo
ROEMHELD will present an integrated concept for handling and changing forming and punching tools at Blechexpo 2021. With this concept, dies or moulds can be quickly and safely stored, transported to the press and positioned, centred and clamped on the machine table... Go to press info
2019-07-18 Römheld Rivi present new service network for Europe, the USA and Asia
The company Römheld Rivi GmbH, specialists in magnetic clamping technology, is presenting its new service network for Europe, the USA and Asia at the K 2019 trade fair... Go to press info
2019-07-12 Solutions for quick die change in automatic punching machines and high-speed presses
With the new catalogue “Everything for quick die change in automatic punching machines and high-speed presses” ROEMHELD addresses prospective customers from the metal forming industry with presses... Go to press info
2019-02-20 Variety of Carrying Consoles for Quick Die Exchange on Presses
Reduced Delivery Terms for Driven and Undriven Consoles. All-in-One Solutions for the Forming Industry... Go to press info
2018-09-14 ROEMHELD at the AMB: Industry 4.0 applications and 5-axis machining
Clamping elements for 5-axis machining, Industry 4.0 applications and automation are the focus of this year’s AMB product show of the ROEMHELD Group... Go to press info
2018-04-09 New variant configurator for roller and ball bars on presses
The new ROEMHELD Internet variant configurator allows potential customers to comfortly compile their customised roller and ball bars for exchanging dies on presses... Go to press info
2018-04-05 “Rotorlock” locking system now rated for transverse forces of up to 7,500 kN
ROEMHELD has improved the performance of its modular locking system “Rotorlock” for the inspection and maintenance of wind power stations. With a transverse force absorption of up to 7,500 kN... Go to press info
2018-02-14 ROEMHELD at the Metav: flexible, quick and safe workpiece clamping
Especially for contract manufacturers and companies who want to automate their production processes, ROEMHELD presents at the Metav a wide range of flexible workholding elements and systems... Go to press info
2016-07-28 Solutions for an efficient, partly automated and Industry 4.0 capable hand assembly
The group of companies showed, among other things, two workplace solutions for the assembly of differential gears and brake cylinders... Go to press info
2014-02-14 Solutions from Clamping + Manufacturing Technology
ROEMHELD at the Metav: The main focus is on components for time-saving set up, clamping in confined spaces and electrically driven elements. The new products include for example bore clamps for direct clamping of components without adapter plates. Also shown are space-saving swing clamps without swing stroke and compact clamps... Go to press info
2013-08-26 ROEMHELD at the EMO: Many new clamping elements
With numerous innovations in power workholding ROEMHELD present themselves at the EMO. Included in particular are compact elements, components for increased safety, automation solutions for purely... Go to press info
