Innovalia Metrology
276
Innovalia Metrology
276
Do you know the new fixture kits from Innovalia Metrology yet?
MarketingInnovalia Metrology Munich on November 30, 2017 at 2:01 AM
Innovalia Metrology’s standard fixture solutions can improve the throughput, reproducibility and accuracy of your inspection process by providing quick and repeatable fixturing set-ups for your components.
Our fixturing solutions can be assembled very quickly to increase throughput and avoid delays in inspection. They have been designed for small and medium size parts for vertical and horizontal inspection. Every component is modular and compatible with the other components to create a multifunction and reusable fixture solution.
The Innovalia Metrology fixture kits are the most complete. Each kit has an aluminum plate, which increases wear resistance. Our fixturing components are easily adjustable and designed to hold components firmly with the minimum necessary force to avoid damage or distortion.
Create your own Fixture Kit:
Fixturing components are easily adjustable and designed to hold components firmly with the minimum necessary force to avoid damage or distortion. Download our brochure and build with our componentes your own Fixture Kit.
Your message
