The VULCANO2 is a new mechanical bearing stacked-axes architecture. It is a based solution allowing the users to reach higher throughput, duty cycles or to serve heavier payloads with no loss of repeatability or of accuracy. The standardized product are shaped with XY and XYT configurations which, thanks to footprint, allow easier drop-in solutions to equipment with lower dynamics stages.Go to press info
2020-01-27
Z3TM: new combined module
The Z3TM is enlarging the portfolio of modules serving motion platforms. This module adds four independent degrees of freedom, namely along one rotary, one vertical and two oblique axes. By design, this optional module enables complete fulfillment of wafer motion profiles for advanced semiconductor applications, thus providing OEMs with a turn-key solution for any semiconductor technology.Go to press info
2020-01-27
CHARON2: extension of the platform family
ETEL extends its stacked platform family by adding a new standard stroke to the existing platforms as well as new configurations with X, XT, XZ3TM and XYZ3TM.Go to press info
2020-01-27
TELICA: dual gantry motion system
TELICA is a new multi-axes platform primarily dedicated to semiconductor back-end applications. It is a dual gantry architecture providing motion along 3 degrees of freedom, X, Y and Z, for a total number of 8 controlled axes. It is designed to fulfill the most challenging requirements of advanced die bonding processes, µ-LED bonding, dispensing applications and more.Go to press info
2019-03-26
New IL+ ironless linear motors
ETEL is introducing the IL+ technology on the famous ILF and ILM linear motors. The new ILF+ and ILM+ feature an optional forced air-cooling kit to improve the performance.Go to press info
2019-02-11
EtherCAT on AccurET
All AccurET modular controllers are now compatible with EtherCAT communication bus. It brings the features of high-end controllers in your machine with minimal integration effort making the performance gains visible straightaway.Go to press info
2019-01-08
TMB+: Closed cooling family
All the TMB+ torque motors are now available with an optional cooling jacket. The jacket is available with radial or axial water inlet/outlet to accommodate any machine design. ETEL is providing a solution that removes the burden of water tightness from the machine designers.Go to press info
2018-08-06
CHARON2: New modular standard platform
CHARON2 is a new semiconductor-oriented XY, XYT, ..., stacked system, backward compatible with existing modules and options. CHARON2 design extends CHARON use cases into the space of higher dynamics and larger payloads, with further improvement on accuracy and repeatability.Go to press info
2017-11-09
New short stroke actuator
ETEL is pleased to announce its new ZAO force controlled actuator as entering its already broad range of advanced motion systems.It is an actuator featuring a frictionless bearing arrangement and a light moving mass, ensuring very low and repeatable force application as well as low force overshoot at impact on a contact surface.Go to press info
2017-11-08
New IMTHP variant
ETEL is introducing a new variant of its IMTHP (temperature monitoring device) that will provide the same functionality as the existing one but fully based on PT1000 sensors (reading & emulating) instead of KTYs.Go to press info
2017-02-06
A new member of the module portfolio
ETEL is proud to officially introduce the DXR+ as a new member of its module portfolio.
The DXR+ is the “entry level” rotary module featuring a compact design, light mass, large hollow shaft and providing the right performance to cost ratio for mid-end applications in semiconductor and electronics. This product enlarges the number of modules that can sit on top of the existing XY platforms.Go to press info
2017-01-16
New LMG and LMS size
ETEL extends its existing LMG and LMS linear motors families with the LMG20 and LMS20 range. These 6 new motors (available with two different winding types except for LMS20-100) are new alternatives for many linear motor applications.Go to press info
2017-01-11
AccurET VHP – Very High Performance Controllers
ETEL designed the AccurET VHP to reach sub-nanometer position stability combined with extremely low tracking errors during dynamic motions and to control the most demanding axes in terms of speed accuracy. AccurET VHP range was shown, for the first time, at SPS/IPC Drives in Nuremberg (Germany) in November 2016.Go to press info
2016-11-16
New Vulcano XY: the modular standard platform
ETEL is proud to present its new VULCANO XY system – a three-piece-design allowing a compact and cost engineered solution, coupled to mechanical bearings and high-end optical encoders. This platform can easily be coupled with a rotary module RTTB or the brand new Z3TH combined module. This latter provides a Tip and Tilt correction, a double Z-axes, 364° Theta rotation and 4 degrees of freedom.Go to press info
2016-11-11
TMB+: New torque motors family
ETEL is renewing its torque motor product range by adding a new motor type, the TMB+. TMB+ is an evolution of the renowned TMB Torque Motor that provides a combination of increased performance and new features while maintaining the interfaces of existing motors.Go to press info
2016-03-17
RTMBi: Next-generation of indexing table
ETEL’s RTMB high precision indexing tables have been a trusted solution for over 10 years, with thousands of products operating in a variety of industries including automation, electronics, and back-end semiconductor manufacturing. Now, ETEL is proud to announce the next generation of high performance indexing tables: the RTMBi. By combining ETEL’s high efficiency torque motors with...Go to press info
2016-02-18
Keep your machine QuiET! A new solution for vibration isolation!
ETEL is very proud to announce the release of its new QuiET - Active Isolation System. From now on, an advanced motion platform from ETEL does not only include the motion system and its associated motion controllers but can also benefit from its proprietary active isolation system. This makes ETEL the only Motion System Supplier in the world offering a so large scope of supply!Go to press info
This website uses cookies
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
