587,535 active members*
2,538 visitors online*
Results 1 to 5 of 5
    Feb 2022
    DIY Vacuum Box Question
    Hi all, newbie here - so many forums, not sure I'm posting this in the right place...
    I'm getting my first CNC, and need to build a vacuum hold down system for some small scale production work, mainly cutting thin acrylic sheet. I've been researching for a while now, and bought two vacuum motors to build a DIY system. Hold down will only be 24"x48". Many of the designs I've seen include enclosing the vacuum motors in a box, but I've also seen some versions that simply have the motors mounted out in the open. Is enclosing them in a box really necessary? Is it for sound, or fire safety, or? Most of what I read is about getting fresh air to the motors and keeping them cool, which would suggest not enclosing them in a box would be ideal? I will be be able to pass my dust collection and vacuum hold down pipes through a wall, and house the loud motors in a sort of open loft space, outside my work area, so noise is less of a concern. Trying to keep things simple, if possible. I've seen a couple posts mention the Gary Campbell DIY design, but I can't seem to locate the original thread for that vacuum box, or any plans for it. Looking for a little tutelage - thanks so much for the help.
    Best, Peter
    Jan 2013
    228
    Re: DIY Vacuum Box Question
    Did a quick look and the Gary Campbell system looks to be just for noise, while allowing a large flow of air for cooling. If you are going to put them in a different room I would just let them run in the open.
    I have use my shop vac for a hold down in the past. and the noise gets pretty annoying even with headphones on.
    35538
    It's on ShopBot's forum.
    I just got done building myself a DIY vac pump setup actually. It's based off of various other DIY reports on forums and YouTube.I used 4 of the Ametek 122178-18 motors as they don't require "make up air" or a small air bypass to let the motor s cool themselves. They also seem to be a bit more robust with longer bearing brushes as well. With just 2 of them on for 2 - 2'x4' zones I saw 8.5 InHg which I was really happy with! Willing to share plans if anyone would like.
    I built an enclosure with a baffle system as I had to have this mounted right next to the router and couldn't remote locate; though aside from a metal box I could only see the enclosure adding to the fire possibility. lol. I think the enclosure is nice as well to just have a complete box system with all enclosed wiring and its just tidy
    That being said I don't see how it would be a necessity to have a full enclosure and one gentleman on YouTube did just that.
    https://www.youtube.com/watch?v=kk-yCqwZ9fU
    My baffle system seemed to take the sharp "ring" or note out of the sound I was familiar with from a Storm Vac on a Camaster router I had.
    I'm doing similar work to the OP with Polycarb and HDPE starboard and the vac motors through a 1/4 or 3/4in HDPE sheet works fantastic!
    May 2009
    Hello,
    I really appreciate you sharing your vac box build. We are going to build one just like yours.
    We will be cutting 1/4" HDPE Starboard smaller parts.
    Question---The Starboard has some texture --Does your vac-set-up table work well in holding down the textured HDPE Starboard? You mentioned your are cutting HDPE Starboard.
    Thank You,
    Trent
    [email protected]
  1. Wanted Feedback of Hurricane Black box Vacuum System
    By Larken in forum Commercial CNC Wood Routers
    Last Post: 06-12-2019, 01:30 AM
  2. DIY Vacuum Pump for 4x6 vacuum bed
    By 1Jumper10 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-18-2018, 11:31 PM
  3. Vacuum forming a two piece box
    By cjonesy20 in forum Vacuum forming, Thermoforming etc
    Last Post: 04-07-2015, 09:21 PM
  4. diy gear box
    By eloid in forum MetalWork Discussion
    Last Post: 11-14-2007, 02:53 AM
