603,302 active members*
2,882 visitors online*
IndustryArena Forum: Arduino
Page 1 of 11 123
Threads 1 to 20 of 209
Discuss Arduino programming here.
    06-15-2025, 05:09 PM Go to last post
  1. Z-axis not moving up or down - Please Help
    Started by HRGreatCareer, 03-14-2025 07:04 PM
    manually, move, moved, xe-pro, z-axis
    03-15-2025, 11:39 PM Go to last post
  2. Arduino GRBL - wrong diagonal movement
    Started by emosms, 02-11-2025 02:09 AM
    axis, diagonal, inverted, movement, x-y
    02-23-2025, 11:46 PM Go to last post
  3. UGS/GRBL Jogging Problem
    Started by steveries, 02-12-2025 01:35 AM
    02-13-2025, 05:50 PM Go to last post
  4. GRBL servo Z axis + unipolar driver library
    Started by emosms, 02-01-2025 04:59 PM
    axis, library, mod, motors, servo
    02-11-2025, 01:55 AM Go to last post
  5. New stepper driver doesn't work hbs57h
    Started by Blocheren, 02-02-2025 09:58 AM
    driver, move, small, stepper, twist
    02-02-2025, 11:19 PM Go to last post
  6. Post Teensy + T41U5XBB
    Started by oscmejia08, 01-29-2025 04:00 AM
    01-30-2025, 10:59 PM Go to last post
  7. digitizing software for GRBL/UGS arduino system??
    Started by tkms002, 01-16-2024 07:01 PM
    arduino, cnc, digitize, software, suggest
    01-10-2025, 05:02 PM Go to last post
  8. GRBL not looking ahead?
    Started by ChaiChai, 10-25-2024 12:19 PM
    cnc, g-code, grbl, laser
    11-28-2024, 10:43 PM Go to last post
  9. Start / resume on 3018 control board
    Started by Jelandis, 09-28-2024 08:22 PM
    boards, cnc, code, machine, switch
    10-06-2024, 10:22 PM Go to last post
  10. Question What's wrong with my arduino relay?
    Started by Thampitakky, 09-06-2024 09:47 AM
    arduino, power issue, relay
    09-07-2024, 10:56 PM Go to last post
    08-11-2024, 10:16 PM Go to last post
  11. Question RnR usb cnc controller with ESTLCAM
    Started by AnodasTeam, 06-10-2024 12:22 PM
    board, cnc, cnc usb controller, estlcam, rnr motioncontroller
    06-19-2024, 10:33 AM Go to last post
    06-18-2024, 10:10 PM Go to last post
  12. UGS/Teensy CNC with non-linear travel/motion
    Started by oscmejia08, 06-11-2024 01:44 AM
    06-17-2024, 10:44 PM Go to last post
  13. CNC cuts 25% larger than design.
    Started by macjorg, 03-08-2024 10:41 PM
    25%, cnc, design, larger, xpro
    03-10-2024, 04:49 AM Go to last post
  14. GRBL Alignment Problem
    Started by Fraesi1, 03-06-2024 10:39 PM
    03-07-2024, 09:28 AM Go to last post
  15. troubleshooting non linear motion on axis
    Started by d954r, 02-27-2024 03:09 AM
    belt, motor, move, problem, table
    03-02-2024, 12:08 AM Go to last post
  16. ARDUINO, DM542T and Stepper
    Started by douglaskeene, 02-29-2024 07:46 PM
    02-29-2024, 07:46 PM Go to last post
  17. Arduino / driver issue
    Started by Willv, 01-10-2024 11:52 AM
    01-10-2024, 11:12 PM Go to last post
Page 1 of 11 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
